Thank you for your suggestion, I did implement it today and it works a charm I would most probably not have been able to come up with that on my own. Quite simple rules for something that works more or less like the design pattern for long and short press
rule 'long/short press button rule button up' do
changed button_up, to: ON
run { logger.info("button UP changed event")}
run do
if button_up.on? and lamp_cluster.off?
logger.info("turning light on")
lamp_cluster << 30
java_import java.time.ZonedDateTime
timer = after(2.second) do
if button_up.on?
logger.info("button still ON, sending increase command, rescheduling")
lamp_cluster.brighten(10)
timer.reschedule(ZonedDateTime.now.plus(Java::JavaTime::Duration.ofSeconds(2)))
rule 'long/short press rule button down' do
changed button_down, to: ON
run { logger.info("button DOWN changed event")}
dimming = false
run do
if button_down.on?
logger.info("button still ON, sending decrease command, rescheduling")
lamp_cluster.dim(10)
dimming = true
else
if dimming == false
logger.info("button OFF, sending off command")
lamp_cluster.off
dimming = false
dimming = false
all of this achieved without casting or converting a single type very slick indeed. With the wrappers around the timer objects it would be even more slick.
But if one could have a trigger function that works for repeated time intervals, as well as time intervals that are shorter than a certain period of time, that could compress this rule very much indeed. Like I suggested, but something along the lines of changed ... for: less than 1.second
next is to try implementing a state machine with a state machine gem. I have done some preliminary testing to show that the gem file is installed, loaded, I have initialised the class and it all works, now I just have to rework (and understand) the example to work in my situation. Will report back in due time.
