Design Pattern: What is a Design Pattern and How Do I Use Them
Edit: Updates for OH 4.
What Is a Design Pattern (DP)
A DP is a concept borrowed from software engineering that is in turn borrowed from architecture. A DP is a general and reusable solution to a common problem. But the solution is not complete. Instead it is a template that one can apply to a lot of different situations with minor modifications and customizations.
The DPs posted to this forum will usually include a complete solution as an example implementation of the DP. But do not assume that the DP is only applicable in that specific example context. A DP is generic and should apply to a number of situations.
Finally, a DP rarely stands alone. They are often closely related to other DPs and many solutions will include multiple DPs, sometimes within just a few lines of code.
What a Design Pattern Is Not
As mentioned above, a DP is not a comprehensive example. They are a template that one can follow to solve a given class of problems one may encounter while developing Rules.
The example code that is included with the DPs may not be fully explained. The purpose of the example code is to illustrate the DP only. But since the DPs are only templates and not complete in and of themselves, the example code will necessarily include additional code. It is your task to generalize the example code to apply it to your specific situation.
In many cases, a library exists that can be used that implements most of the details for you. As part of the updates to the DP posts written by @rlkoshak the examples have been (or will be soon) migrated to show how the DP is solved using published rule templates, block libraries, and libraries. If you use a different language you might need to translate the example code to your language of choice.
What Should I Know to Use a DP
Because a DP is not a complete solution, the reader needs to possess a few skills in order to apply them to their situation:
  • the basics of how to define Items and use them in Rules code
  • the parts of a Rule and how to identify those parts in various contexts, including the ability to recognize the difference between a file based rule and a managed rule
  • the ability to follow a block of code and understand at a basic level what the code does
  • the ability to translate a block of code from one rules language to another where necessary
  • the ability to recognize and deal with code in a block that is not fully explained or defined in the DP text (e.g. reference to Items not defined in the current DP)
  • the ability to generalize an example to multiple situations
Languages
The DPs may include examples in multiple different supported programming languages. They may include UI rules examples, text based rule examples, or both. The purpose of the DP is to show a way of solving a problem, not a copy and paste example to simply use as is. For that see Rule Templates.
Current Design Patterns
Design Pattern: Motion Sensor Timer
Design Pattern - Timer Management
Design Pattern: Switch & Dimmer
Design Pattern: Time of Last Update
Using HABMin rules in HABPanel
Design Pattern: Associated Items
Issues with implicit variables newState and triggeringItem in 3.0.0
Design Pattern: Encoding and Accessing Values in Rules
Design Pattern: Human Readable Names in Messages
Design Pattern: Manual Trigger Detection
Design Pattern: Recursive Timers
Design Pattern: Using Item Metadata as an Alternative to Several DPs
Design Pattern: Rate Limit
Design Pattern: Proxy Item
Design Pattern: Unbound Item (aka Virtual Item)
Design Pattern: Separation of Behaviors
Design Pattern: Sensor Aggregation
Design Pattern: Group Based Persistence
Design Patterns: Generic Is Alive
Design Pattern: Rule Refresh
Design Pattern: Debounce
Design Pattern: Hysteresis
Design Pattern: Rule Disable
Design Pattern: Working with Groups in Rules
[SOLVED] In sitemaps, how to create a view having item name and item value
Smart Virtual Thermostat (beta version)
[SOLVED]Scene light and persistence rrd4j
[SOLVED] My First Rule: Any advice?
Design Pattern: State Machine Driven Groups
Design Pattern: DRY, How Not to Repeat Yourself in Rules DSL
Design Pattern: Simple State Machine (e.g. Time Of Day)
Design Pattern: How to Structure a Rule
Best practice for small coding (Design Pattern)
GDPR Compliance and NEW WEBSITE!
Design Pattern: Looping Timers
What are your top 3 automations
Magical light scenes
Error with openhab(?) py script 100_DirectoryTrigger.py after Update to 4.0.1
Design Pattern: Gate Keeper
[No longer relevant on OH 3.0+] Design Pattern: Rule Latching
Design Pattern: Expire Binding Based Timers
Design Pattern: Cascading Timers
Upgrade 2 to 3 strategy/planning
Design Pattern: Do While
Design Pattern: Cancel Activity
