[SOLVED]Scene light and persistence rrd4j
  • Platform information:
    • Hardware:RPI3
    • openhab 2.4.0
Hello, I hope to find a solution.
I have set up my entire house, now I would like to go a little further in the persistence. but I can not understand the operation.
What I want to do:
my wife has an office in the dining room.
I want that when she turns on her computer, only some lights (ikea trafri binding) shine stronger, for that I arrive, thanks to the following rule below, and then when she turns off, lights came back to the previous mood light or previous state of light
/*laptop
rule "laptop ON"
    Item Laptop changed from OFF to ON
          if ((Lumieres.state == OFF) && (((hour >= 18)  && (hour <= 23 )) || ((hour >= 4) && (hour <= 8 )))) {
  logInfo("laptop ON", "laptop ON Ambiance bureau")
  sendCommand(Bureau, ON)}
        if (Lumieres.state == ON){
  sendCommand(ArcheDroite, 100)
  sendCommand(ArcheGauche, 100)
  sendCommand(ArcheMilieu, 100)
  sendCommand(Plafond_Salle_A_Manger_3, 100)
my light moods are manage by rules like this one
rule "bureau"
        Item Bureau received command ON
      sendCommand(Lumieres_Arche, 90)
        postUpdate(Lumieres, ON)
        postUpdate(Ambiance_Apero, OFF)
        postUpdate(Ambiance_Diner, OFF)
        postUpdate(Ambiance_Matin, OFF)
        postUpdate(Ambiance_Film_Tele, OFF)
        postUpdate(Ambiance_Tele, OFF)
        postUpdate(Ambiance_Pleine_lumiere, OFF)
        postUpdate(Ambiance_du_Soir, OFF)
        postUpdate(Ambiance_cosy, OFF)
        postUpdate(Ambiance_VP, OFF)
        postUpdate(Ambiance_feutree, OFF)
        postUpdate(Bureau, ON)
, I know, it would be simpler to do like this way :Design Pattern: What is a Design Pattern and How Do I Use Them
but mine is more comprehensive for my mind.
I understood that to recover a previous state I needed a persistence in openhab, so I install rr4dj, (maybe another type would be more appreciated for my case, I’m confused about it), I have configure the following way with the rrd4j.persist file in the persistence folder, this way:
Strategies {
    everyMinute : "0 * * * * ?"
    everyHour 	: "0 0 * * * ?"
    everyDay	: "0 0 0 * * ?"
    default = everyChange
Items {
    // persist items on every change and every minute
    * : strategy = everyChange, everyMinute
    Lumieres: strategy = everyChange
I also defined the default persistence in openhab
Some people advise to write something in the cfg file, but i’m not sure, so i didn’t touched it?
and now i’m stuck with my rule:
i don’t know what to do
convert to decimal type ?
restores (item.previous.state)?
when to store my value etc…
i tried this rule: but nothing happens:
rule "laptop OFF"
    Item Laptop changed from ON to OFF
var LumieresStates = storeStates(Lumieres_Arche,Lumieres_PLafond_Salle_a_manger)
restoreStates(LumieresStates)
  logInfo("laptop OFF", "laptop OFF Ambiance bureau")
  postUpdate(Bureau, OFF)
i’m aware that this kind of topic is reccurent, i followed multiples topic about persistence, make multiples test, but i’m stuck on something that it sure i don’t understand. I need to understand. thx by advance.
https://www.smarthomeblog.net/openhab-persistence-tutorial/
First things first, please use the method instead of the action:
You should do:
      Lumieres_Arche.sendCommand(90)
        Lumieres.postUpdate(ON)
Second, rrd4j only store number values so that would be the wrong choice of persistence
Third, you are almost there:
var LumieresStates //Global variable declared at the top of the rules file
rule "laptop ON"
        LumieresStates = storeStates(Bureau)
        Bureau.sendCommand(ON)
    if (Lumieres.state == ON) {
        LumieresStates = storeStates(ArcheDroite, ArcheGauche, Lumieres_PLafond_Salle_A_manger_3)
        ArcheDroite.sendCommand(100)
        ArcheGauche.sendCommand(100)
        ArcheMilieu.sendCommand(100)
        Plafond_Salle_A_Manger_3.sendCommand(100)
rule "laptop OFF"
    if (restoreStates !== null) {
No persistence needed
First, thx you vincent…again…you are everywhere:slight_smile:
first for the method:
i came back to openhab documentation to see the difference and i understand why you said that
second why i don’t need persistence?
third, the rule you wrote return an error:
2019-10-09 17:15:16.405 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'laptop OFF': An error occurred during the script execution: index=0, size=0
just to understand can you confirm?
var LumieresStates
var Number hour = now.getHourOfDay
/*laptop*/
rule "laptop ON"
    Item Laptop changed from OFF to ON or
    Item Boutton received command ON
    if ((Lumieres.state == OFF) && (((hour >= 17)  && (hour <= 23 )) || ((hour >= 4) && (hour <= 8 )))) {
        LumieresStates = storeStates(Bureau)                                                    // store bureau lights scene states when item ON
        LumieresStates = storeStates(ArcheDroite, ArcheGauche, Plafond_Salle_A_Manger_3)        // store global lights states
rule "laptop OFF"
    Item Laptop changed from ON to OFF or
    Item Boutton received command OFF
    if (restoreStates !== null) {                                   // can u explain this line ?
        restoreStates(LumieresStates)                               // restore light state to previous one
Apologies:
rule "laptop OFF"
    if (LumiereStates !== null) {                                   // Does it make sense now?
You don’t need persistence because storeStates and restoreStates don’t need persistence
You are storing the states in a variable not a database
Offtopic question:
Are the methods “storestates” and " restoresrates" part of the standard textual rules?
IMHO they 're only mentioned for the JSR223, which needs the NGRE.
okay i make some tests to understand and now it’s clear to me, i’ve change the rule in order to switch all the lights off when lumieres.state ==OFF before triggering “bureau”
rule "laptop ON"
        LumieresStates = storeStates(Lumieres)                                     // <===  HERE
rule "laptop OFF"
    if (LumieresStates !== null) {
        logInfo("laptop OFF", "laptop OFF Ambiance bureau1")
and thx to you i really understand the variables role !!! thank you again vincent
They are part of the DSL and are actions not methods
There is documentation… somewhere…
