Design Pattern: Do While
Problem Statement
Sometimes a user wants to perform some sort of action or activate polling during a certain period of time after another event occurs.
This Design Pattern is deprecated. Please see Design Pattern: Looping Timers for a better approach.
Why not more efficiently val end = now.plusMinutes(10)?
Because I was in a hurry and clearly didn’t think it through. :blush:
That is better. Editing the original.
This always gave me syntax errors, as “end” is a reserved keyword? I ended up using another name for the variable “end”, then the example works fine.
Thanks, but really I should remove Example 2. You should not have a long running Rule like that. It can be really bad. Use Design Pattern: Looping Timers instead.
