Don’t use async, await and promises. By using those you push the execution into the background and the rule exits.
function performSomeTask() {
console.info("Starting task");
java.Type('java.lang.Thread').sleep(2000);
console.info("Task completed");
performSomeTask();
This isn’t a web page nor is it a Node module. There’s no event loop you need to wait around for (and in fact I wasn’t even aware that Promise even worked now, it didn’t use to.
If you want the rule to block while it’s running just write your straight forward code and while that code is running, OH will queue up subsequent runs of the rule and work them off in series.
If you do in fact want to run something in the background and not block the rule, the standard approach is to use setTimeout or use an openHAB Timer. Once advantage of using an openHAB Timer is it can be shared across rules using the shared cache.
In OH3.4 I had used java.util.concurrent.CompletableFuture. With JSScripting in OH4 this doesn`t work anymore, so I wanted to switch to async / await. But this is probably also not purposeful.
ECMA - 262 Edition 5.1:
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.core.model.script." + ctx.ruleUID);
var ZonedDateTime = Java.type("java.time.ZonedDateTime");
var ScriptExecution = Java.type("org.openhab.core.model.script.actions.ScriptExecution");
var CompletableFuture = Java.type("java.util.concurrent.CompletableFuture");
function exampleFunction1() {
var future1 = new CompletableFuture();
// Simulate an asynchronous operation
ScriptExecution.createTimer(ZonedDateTime.now().plusSeconds(2), function() {
logger.info("Completing Task 1");
future1.complete("Result 1");
return future1;
function exampleFunction2() {
var future2 = new CompletableFuture();
ScriptExecution.createTimer(ZonedDateTime.now().plusSeconds(3), function() {
logger.info("Completing Task 2");
future2.complete("Result 2");
return future2;
var future1 = exampleFunction1();
var future2 = exampleFunction2();
CompletableFuture.allOf(future1, future2).join();
logger.info("Both tasks completed");
logger.info("Result of Task 1: " + future1.get());
logger.info("Result of Task 2: " + future2.get());
I have rewritten this as follows: ECMAScript 262 Edition 11:
actions.ScriptExecution.createTimer(time.ZonedDateTime.now().plusSeconds(2), function() {
console.info("Completing Task 1");
return future1;
actions.ScriptExecution.createTimer(time.ZonedDateTime.now().plusSeconds(3), function() {
console.info("Completing Task 2");
return future2;
console.info("Both tasks completed");
console.info("Result of Task 1: " + future1.get());
console.info("Result of Task 2: " + future2.get());
Unfortunately this does not work, but blocks the rule.
Even CompletableFuture is way over complicated. Again, OH rules don’t run in an event loop. If you want something to run in the future, use createTimer or setTimeout. If you want the rule to block until the code has completed, don’t use anything. All that stuff is handled for you.
exampleFunction1();
exampleFunction2();
That will call exampleFunction1 and exampleFunction2, blocking the rule while it’s running, meaning that if the rule gets triggered again it will queue up the subsequent triggers and work them off in series and in order.
That’s the use case you describe.
In the case where you really do want to run something in the background at a certain time, use setTimeout or createTimer to schedule execution of a function. This does not block the rule though. Usually subsequent triggers of the rule will look to see if the timer already exists and do something with it (cancel it, reschedule it, etc.).
All this work to schedule something into the background and block the rule until the background stuff is completed is overly complicated and completely unnecessary. This isn’t a node application or a browser where you have to deal with an event loop. This isn’t a J2EE application where access to Threads is available but tightly controlled.
