JSON Error
ive problems with JSON, but i dont no why. perhaps anyone can help me.
my JSON file is here:
http://www.schatthaus-wetter.de/daily.json
my LOG:
2018-05-09 19:36:22.580 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.outTemp_raw)' threw an exception. [response={
"title": "Aktuelle Werte",
"location": "Pewsum, Niedersachen - DE",
"time": "09.05.2018 19:35:00",
"time2": "19:35",
"lat": "53° 26.60' N",
"lon": "007° 05.76' O",
"alt": "0 meter",
"hardware": "TFA Nexus",
"uptime": "8 Tage, 9 Stunden, 21 Minuten",
"serverUptime": "50 Tage, 23 Stunden, 0 Minuten",
"weewxVersion": "3.8.0",
"outTemp": "25,5°C",
"outTemp_raw": "25.5",
"PoolTemp": "20,5°C",
"PoolTemp_raw": "20.5"
"windchill": "28,0°C",
"heatIndex": "25,5°C",
"dewpoint": "14,0°C",
"humidity": "49%",
"humidity_raw": "48.9666666667",
"insideHumidity": "57%",
"barometer": "1005 mbar",
"barometer_raw": "1005.375",
"barometerTrendDelta": "3 Stunden",
"barometerTrendData": "-0 mbar",
"windSpeed": "4,1 km/h",
"windSpeed_raw": "4.08236928",
"windDir": "358°",
"windDirText": "N",
"windGust": "7,1 km/h",
"windGust_raw": "7.0811136",
"windGustDir": "   N/A",
"rainRate": "0,0 mm/h",
"rainRate_raw": "0.0"
org.openhab.core.transform.TransformationException: An error occurred while transforming JSON expression.
	at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) [211:org.openhab.core.compat1x:2.2.0]
	at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:194) [240:org.openhab.binding.http:1.11.0]
	at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:144) [211:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:166) [211:org.openhab.core.compat1x:2.2.0
my items:
Group Wetterstation     "Wetterstation"
String WetS_Version        "Version"                          <clock>                 (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:12000:JSONPATH($.weewxVersion)]"}
Number WetS_Temp          "Aussentemperatur [%.1f °C]"        <icons8_temperatur>     (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:12000:JSONPATH($.outTemp_raw)]"}
Number WetS_Regenr        "Regenrate [%.1f mm/h]"             <icons8_regen>          (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:12000:JSONPATH($.rainRate_raw)]"}
Number WS_Luftfeuchte   "Luftfeuchtigkeit [%.1f %%]"        <icons8_feuchtigkeit>   (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:120000:JSONPATH($.humidity_raw)]"}
Number WS_Luftdruck     "Luftdruck [%.1f mBar]"             <icons8_luftdruck>      (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:120000:JSONPATH($.barometer_raw)]"}
Number WS_Wind          "Windgeschwindigkeit [%.1f km/h]"   <icons8_windsack>       (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:120000:JSONPATH($.windSpeed_raw)]"}
Number WS_Boen          "Windboen [%.1f km/h]"              <icons8_tornado>        (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:120000:JSONPATH($.windGust_raw)]"}
Number WS_PoolTemp      "Pool-Temperatur [%.1f °C]"         <icons8_temperatur>     (Wetterstation)     {http="<[http://www.schatthaus-wetter.de/daily.json:120000:JSONPATH($.PoolTemp_raw)]"}
You miss a comma at the end of the “PoolTemp_raw” line, right before “windshill”
A suggestion use one item to fetch the JSON and then make the transformation and update for all information in a rule. As it seems to me it’s one JSON which information gets distributed to multiple items, this reduces the amount of requests.
At least you should use the http cache.
https://docs.openhab.org/addons/bindings/http1/readme.html#example-of-how-to-configure-an-http-cache-item
