Trying to install openhabian on a intel nuc running ubuntu server I get this error in regards to jq (JSON)
Its a fresh install of both linux and openhabian. openhabian seems to be running fine, but gives out occational errors of this type.
jq: error: Invalid escape at line 1, column 4 (while parsing '"\x"') at <top-level>, line 1:
.Platform.Value = "\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff \xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff/DN2820FYK, BIOS FYBYT10H.86A.0055.2016.0919.1948 09/19/2016
jq: 66 compile errors
2018-01-18 08:57:03.732 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://10.0.0.2:8080
2018-01-18 08:57:03.747 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://10.0.0.2:8443
2018-01-18 08:57:17.970 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2018-01-18 08:57:18.243 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://10.0.0.2:8080
2018-01-18 08:57:18.248 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://10.0.0.2:8443
2018-01-18 08:57:20.023 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-01-18 09:01:16.369 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2018-01-18 09:01:16.428 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://10.0.0.2:8080
2018-01-18 09:01:16.430 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://10.0.0.2:8443
2018-01-18 09:03:02.916 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-01-18 09:03:03.229 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-01-18 09:03:03.301 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-01-18 09:03:03.339 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-01-18 09:13:20.756 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-01-18 09:13:31.395 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-01-18 09:13:31.411 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-01-18 09:13:31.421 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-01-18 09:13:31.447 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2018-01-18 09:02:57.820 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2018-01-18 09:03:03.367 [thome.event.ExtensionEvent] - Extension 'ui-homebuilder' has been installed.
2018-01-18 09:03:03.374 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2018-01-18 09:03:03.378 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2018-01-18 09:03:03.379 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2018-01-18 09:23:47.243 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-01-18 09:23:48.319 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://10.0.0.2:8080
2018-01-18 09:23:48.326 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://10.0.0.2:8443
2018-01-18 09:23:59.291 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-01-18 09:24:02.668 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-01-18 09:24:02.779 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-01-18 09:24:02.900 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
