Recently I received my first Shelly Plus 2PM.
Since they are not yet supported by the Shelly binding, I would like to integrate them via MQTT.
I managed to read their output (relais) status via JSONPath transformation.
Also for the command channel I found a working solution, but it seems to be dirty hack.
What is the proper JSONPATH transformation to send a string like this?
"method": "Switch.Set",
"params": {
"id": 0,
"on": false
My dirty hack makes use of “formatBeforePublish”. Code below:
UID: mqtt:topic:e3daee878f:shellyplus2pm-test
label: shellyplus2pm-test
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:e3daee878f
channels:
- id: Output0
channelTypeUID: mqtt:switch
label: Output0
description: ""
configuration:
commandTopic: shellies/shellyplus2pm-test/rpc
formatBeforePublish: ' {"method":"Switch.Set", "params":{"id":0,"on":%s}}'
stateTopic: shellies/shellyplus2pm-test/status/switch:0
transformationPattern: JSONPATH:$.output
off: "false"
on: "true"
- id: Output1
label: Output1
description: ""
configuration:
formatBeforePublish: ' {"method":"Switch.Set", "params":{"id":1,"on":%s}}'
stateTopic: shellies/shellyplus2pm-test/status/switch:1
off: "false"
on: "true"
Thank you in advance,
Sven
