- Platform information:
- Hardware: Intel laptop
- OS: windows 10
- Java Runtime Environment: 11
- openHAB version:3.4.2
- Issue of the topic:
I have a zigbee blind used through zigbee2mqtt
I have DIMMER item linked to the blind thing channel
I can control the blind by giving a value to the dimmer which sends a message to
zigbee2mqtt/ZB Studio Blind 1/set with the position I want the blind to go to.
For reading the state of the blind I subscribe to
MQTT explorer shows the following message when the blind changes position
zigbee2mqtt/ZB Studio Blind 1 = {“linkquality”:66,“position”:90,“running”:false,“state”:“OPEN”}
In the Channel configuration in the incoming Value Transformations I have
“JSONPATH:$.position”
When I move the blind with a remote control I get the following warning and the item value does not get updated
18:31:01.461 [WARN ] [tt.generic.ChannelStateTransformation] - Transformation service "JSONPATH for pattern $.position" not found!
18:31:01.465 [WARN ] [hab.binding.mqtt.generic.ChannelState] - Command '{"linkquality":78,"position":43,"running":false,"state":"OPEN"}' from channel 'mqtt:topic:d9e1ecaca7:ccbcb0a54b:BlindPosition' not supported by type 'PercentageValue': Unknown String!
18:31:05.086 [WARN ] [tt.generic.ChannelStateTransformation] - Transformation service "JSONPATH for pattern $.position" not found!
18:31:05.090 [WARN ] [hab.binding.mqtt.generic.ChannelState] - Command '{"linkquality":81,"position":33,"running":false,"state":"OPEN"}' from channel 'mqtt:topic:d9e1ecaca7:ccbcb0a54b:BlindPosition' not supported by type 'PercentageValue': Unknown String!
Bundles:list shows that the JSONPath transformation service is installed
Can anyone see what I am doing wrong?
Thank you
