how do I set the proper file encoding for the jython files?
I tried adding in the first line a
# -*- coding: utf-8 -*-
in the beginning but then I get the following error:
javax.script.ScriptException: org.python.antlr.ParseException: org.python.antlr.ParseException: encoding declaration in Unicode string
at org.python.jsr223.PyScriptEngine.scriptException(PyScriptEngine.java:207) ~[jython.jar:na]
at org.python.jsr223.PyScriptEngine.compileScript(PyScriptEngine.java:88) ~[jython.jar:na]
at org.python.jsr223.PyScriptEngine.eval(PyScriptEngine.java:47) ~[jython.jar:na]
at javax.script.AbstractScriptEngine.eval(Unknown Source) ~[na:1.8.0_73]
at org.openhab.core.jsr223.internal.engine.scriptmanager.Script.loadScript(Script.java:91) ~[bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.Script.<init>(Script.java:79) ~[bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.ScriptManager.loadScript(ScriptManager.java:90) [bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.ScriptManager.scriptsChanged(ScriptManager.java:185) [bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.ScriptUpdateWatcher.run(ScriptUpdateWatcher.java:105) [bundlefile:na]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_73]
Caused by: org.python.core.PyException: null
at org.python.core.Py.JavaError(Py.java:546) ~[jython.jar:na]
at org.python.core.ParserFacade.parseExpressionOrModule(ParserFacade.java:129) ~[jython.jar:na]
at org.python.util.PythonInterpreter.compile(PythonInterpreter.java:320) ~[jython.jar:na]
at org.python.util.PythonInterpreter.compile(PythonInterpreter.java:312) ~[jython.jar:na]
at org.python.jsr223.PyScriptEngine.compileScript(PyScriptEngine.java:83) ~[jython.jar:na]
... 8 common frames omitted
Caused by: org.python.antlr.ParseException: encoding declaration in Unicode string
at org.python.core.ParserFacade.prepBufReader(ParserFacade.java:281) ~[jython.jar:na]
at org.python.core.ParserFacade.parseExpressionOrModule(ParserFacade.java:123) ~[jython.jar:na]
... 11 common frames omitted
While googeling I found this should acutally work, but it obviously seems not.
When I remove the entry in the first line, my rule loads fine but I am having problems with special characters like “°C”, “äöü”, etc.
Can anyone point me in the right direction?
I don’t fully understand the reasoning presented there. It seems to work both with or without the comment if the script is interpreted directly from Jython rather than through the JSR223 ScriptEngine.eval function.
I tried both. I also played around with .decode and .encode but I did not manage to get it to work.
My file encoding is utf-8 and I am not including the comment and not including the BOM.
When using the u"°C" it doesn’t work ether.
What is your file encoding?
I run openhab as a daemon so I can’t use print in that context. However, I’ve run standalone Jython scripts that use the JSR223 ScriptEngine class to load scripts that print to the console (Terminal on Mac OS X) and it works correctly (without encoding comment, BOM, etc.). I’ve also logged unicode from from an openhab rule and that worked too.
