I get a DateTime object for the current point in time using DateTime.now(). What I need is this time in time zone UTC. According to the Jodatime API, this can be done using DateTime.now().withZone(DateTimeZone.UTC). However, the DateTimeZone class is not available in jsr233 / JavaScript.
I tried var DateTimeZone = Java.type("org.joda.time.DateTimeZone") but this is throwing an exception the class can’t be found.
You are probably better off using Java’s ZonedDateTime in this context. ZonedDateTime (Java Platform SE 8 ). I don’t know if it is imported by default in JavaScript but if not you can import it and ZoneId.
from org.joda.time import DateTime, DateTimeZone
from core.log import logging, LOG_PREFIX#, log_traceback
LOG = logging.getLogger("{}.TEST".format(LOG_PREFIX))
LOG.warn(DateTime.now().withZone(DateTimeZone.UTC))
And this works in JS…
'use strict';
var OPENHAB_CONF = Java.type("java.lang.System").getenv("OPENHAB_CONF");
load(OPENHAB_CONF + "/automation/lib/javascript/core/actions.js");
var DateTime = Java.type("org.joda.time.DateTime");
var DateTimeZone = Java.type("org.joda.time.DateTimeZone");
LogAction.logWarn("Rules", DateTime.now().withZone(DateTimeZone.UTC));
Using ZonedDateTime…
from java.time import ZoneId
LOG.warn("here [{}], UTC [{}]".format(DateTimeType().zonedDateTime, DateTimeType().zonedDateTime.withZoneSameInstant(ZoneId.of("UTC"))))
… and…
var ZoneId = Java.type("java.time.ZoneId");
LogAction.logWarn("Rules", "here [{}], UTC [{}]", new DateTimeType().zonedDateTime, new DateTimeType().zonedDateTime.withZoneSameInstant(ZoneId.of("UTC")));
Yes, I tried the var DateTimeZone = Java.type("org.joda.time.DateTimeZone"); assignment before, but for my installation it bombs with a java.lang.ClassNotFoundException exception.
I’m on the latest openHABian and latest stable openHAB2 release. I’ll try the ZonedDateTime class in a minute.
2020-01-15 10:42:00.594 [DEBUG] [e.automation.internal.RuleEngineImpl] -
java.lang.RuntimeException: Fail to execute action: 1
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1197) ~[bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:993) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:91) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: java.lang.RuntimeException: java.lang.ClassNotFoundException: org.joda.time.DateTimeZone
at org.openhab.core.automation.module.script.rulesupport.shared.simple.SimpleRule$$NashornJavaAdapter.execute(Unknown Source) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.shared.simple.SimpleRuleActionHandlerDelegate.execute(SimpleRuleActionHandlerDelegate.java:34) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.internal.delegates.SimpleActionHandlerDelegate.execute(SimpleActionHandlerDelegate.java:59) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1189) ~[bundleFile:?]
... 7 more
Caused by: java.lang.ClassNotFoundException: org.joda.time.DateTimeZone
at java.net.URLClassLoader.findClass(URLClassLoader.java:382) ~[?:1.8.0_222]
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_222]
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349) ~[?:1.8.0_222]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_222]
at org.eclipse.osgi.internal.framework.ContextFinder.loadClass(ContextFinder.java:132) ~[org.eclipse.osgi-3.12.100.jar:?]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_222]
at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_222]
at jdk.nashorn.internal.runtime.Context.findClass(Context.java:1051) ~[nashorn.jar:?]
at jdk.nashorn.internal.objects.NativeJava.simpleType(NativeJava.java:498) ~[nashorn.jar:?]
at jdk.nashorn.internal.objects.NativeJava.type(NativeJava.java:322) ~[nashorn.jar:?]
at jdk.nashorn.internal.objects.NativeJava.type(NativeJava.java:314) ~[nashorn.jar:?]
at jdk.nashorn.internal.objects.NativeJava.type(NativeJava.java:310) ~[nashorn.jar:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$236$9972A$\^eval\_.datetime_utc2(<eval>:337) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$234$10329AA$\^eval\_.execute(<eval>:352) ~[?:?]
... 7 more
So this is occurring when the rule is triggered. I only tested using it through the script, not in a rule. Could you post your rule, or better the simplest rule that causes the error?
This works for me on 2.5.1-2…
'use strict';
load(OPENHAB_CONF + '/automation/lib/javascript/core/rules.js');
load(OPENHAB_CONF + '/automation/lib/javascript/core/actions.js');
JSRule({
name: "Test JavaScript rule",
description: "This rule is for testing JavaScript",
triggers: [
CommandEventTrigger("Virtual_Switch_1", null, "Test_Trigger_Name")
execute: function (module, input) {
// LogAction.logWarn("Rules", "Test {}", input['event'].itemCommand)
I have placed both the DateTimeZone and ZoneID versions in Javascript functions:
var datetime_utc2 = function (t /*DateTime*/)
//var DateTime = Java.type("org.joda.time.DateTime"); // doesn't bomb, but not required
var DateTimeZone = Java.type("org.joda.time.DateTimeZone"); // bombs
var t_utc = t.withZone(DateTimeZone.UTC);
logInfo("datetime_utc2(): "+t_utc);
return t_utc;
var datetime_utc3 = function (t /*ZonedDateTime*/)
var t_utc = t.withZoneSameInstant(ZoneId.of("UTC"));
logInfo("datetime_utc3 (): "+t_utc);
return t_utc;
The minimal rule is this one, uncommenting the datetime_utc2 call throws the exception. In case this is working for you, I have either different Java configuration or it is related to 2.5.0-1 vs. 2.5.1-2 openHAB releases.
Your minimal rule gave me errors due to unknown variable ‘me’. I took that out and it ran without errors using utc2.
This works for me…
'use strict';
return t_utc;
datetime_utc2(DateTime.now());
var me = "test"
JSRule({
description: "Rule_Sun_TotalRadiation",
triggers: [
TimerTrigger("0 * * * * ?")
execute: function(module, input) {
//datetime_utc3(new DateTimeType().zonedDateTime);
There were no changes in openHAB core between these releases and there won’t be any in the 2.5.x releases. Are you using the JavaScript helper libraries from here? If so, when was the last time you updated them? Also, which OS and version of Java are you using?
“me” has been the name of the .js file as used in the samples. Not relevant for the test.
I’m using the helper libs linked, actually I installed them yesterday (which is the day I started to migrate from XTend to jsr223). The Java version is the standard installed with openHABian:
The interesting thing is that var DateTime = Java.type("org.joda.time.DateTime");
is working while var DateTimeZone = Java.type("org.joda.time.DateTimeZone");
bombs… Both should be in the same package.
A appreciate the time you take looking into this. And I’d rather have it working using DateTimeZone instead of having a reference to the deprecated DateTimeType in my code… But for now I can live with the ZonedDateTime solution - better that adding the timezone shift manually.
No idea about Jython - I have removed that part during installation.
Java.type(“org.joda.time.DateTimeZone”) crashes when called from within a rule (as discussed) but doesn’t when ran on script top level (i.e. when executed when the script is loaded).
