I managed to create a backup job that does a backup and copies it to a share, and FINALLY got it to work, but now I’m unable to delete the local copy of the file. Anyone spot my issue?!?
The only thing relevant in the openhab log is this: (And these are from my deliberate logging so not an actual issue)
2020-02-20 10:04:00.291 [ERROR] [223.jython.Jython Delete Backups Job] - Delete Local Backups Job Running...
2020-02-20 10:04:00.299 [ERROR] [223.jython.Jython Delete Backups Job] - Delete Local Backups Job Username: openhab
2020-02-20 10:04:00.408 [ERROR] [223.jython.Jython Delete Backups Job] - Delete Local Backups Job Permissions Output:
2020-02-20 10:04:00.470 [ERROR] [223.jython.Jython Delete Backups Job] - Delete Local Backups Job Output:
2020-02-20 10:04:00.472 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule '33a5f59b-d92b-4c26-8776-23a7532d5a3f' is executed.
(I know the sudoers file edit is a security issue but I’m trying to troubleshoot now.)
backup_job.py: (works)
This script uses a decorated cron rule that will generate logs every 10s and can be used to test your initial setup.
It requires this:
sudo apt-get install ncftp
sudo apt-get install samba-client
sudo adduser openhab sudo
sudo usermod -aG sudo openhab
sudo nano -f /etc/sudoers.d/openhab_scripts
openhab ALL=(ALL) NOPASSWD: /usr/share/openhab2/runtime/bin/backup
from core.rules import rule
from core.triggers import when
import subprocess
#from datetime import date
from datetime import datetime, time
@rule("Jython Backup Job", description="Backup Job", tags=["Backup Job tag", "Backup Job"])# description and tags are optional
# Every 5 seconds
#@when("Time cron 0/10 * * * * ?")
# Every minute
#@when("Time cron 0 * * * * ?")
# Every Wednesday at 11:29pm
@when("Time cron 0 00 03 ? * THU")
#@when("Time cron 0 56 09 ? * THU")
def backup(event):
backup.log.error("Backup Job Running...")
# Get hostname
hostnameExec = subprocess.Popen(["hostname"], stdout=subprocess.PIPE)
hostnameOut, hostnameErr = hostnameExec.communicate()
hostnameOut = hostnameOut.rstrip()
backup.log.error("Backup Job Hostname: "+hostnameOut)
# Get todays date & format
#today = date.today()
today = datetime.now()
todayFmt = today.strftime("%Y%m%d_%H%M")
# Set backup path with hostname & date
file = "Backup_" + hostnameOut + "_" + todayFmt + ".zip"
#path = "/etc/openhab2/Backup_" + hostnameOut + "_" + todayFmt + ".zip"
path = "/var/lib/openhab2/backups/Backup_" + hostnameOut + "_" + todayFmt + ".zip"
# Do backup job - sudo $OPENHAB_RUNTIME/bin/backup /etc/openhab2/Backup_openhab1_20200101.zip
backup.log.error("Backup Job Cmd: " + "/usr/share/openhab2/runtime/bin/backup " + path)
backupJobExec = subprocess.Popen(["sudo", "/usr/share/openhab2/runtime/bin/backup", path], stdout=subprocess.PIPE)
backupJobOut, backupJobErr = backupJobExec.communicate()
backup.log.error("Backup Job Cmd Output: " + backupJobOut)
# Upload file via smbclient - works via cmdline: smbclient -U openhabian%password //10.0.0.5/Backup -t 600 -c 'lcd /etc/openhab2 ; put "Backup_openhab1_20200219.zip"'
#uploadCmd = 'lcd /etc/openhab2 ; put "' + file + '"'
uploadCmd = 'lcd /var/lib/openhab2/backups ; put "' + file + '"'
backup.log.error("Backup Job FTP Cmd: "+uploadCmd) # lcd /etc/openhab2 ; put "/etc/openhab2/Backup_openhab1_20200220.zip"
ftpExec = subprocess.Popen(["smbclient", "-U", "openhabian%password", "//10.0.0.5/Backup", "-t", "600", "-c", uploadCmd], stdout=subprocess.PIPE)
ftpOut, ftpErr = ftpExec.communicate()
backup.log.error("Backup Job FTP Upload: "+ftpOut)
delete_backup_jobs.py: (Doesnt delete the files)
This script deletes old local backup files that should have been uploaded already to NAS Backup share
Not sure if this requires these:
# Allow openhab user to execute reboot and poweroff commands
openhab ALL=(ALL) NOPASSWD: ALL
import subprocess
@rule("Jython Delete Backups Job", description="Delete Local Backup Files Job", tags=["Delete Backups Job tag", "Delete Backups Job"])# description and tags are optional
# Every 5 seconds
# Every minute
@when("Time cron 0 04 10 ? * THU")
def backup(event):
backup.log.error("Delete Local Backups Job Running...")
# Get username running this script
import getpass
username = getpass.getuser()
backup.log.error("Delete Local Backups Job Username: "+username)
# Set permissions - sudo chmod -R 777 /var/lib/grafana/plugins
perExec = subprocess.Popen(["sudo", "chmod", "-R", "777", "/var/lib/openhab2/backups"], stdout=subprocess.PIPE)
perOut, perErr = perExec.communicate()
backup.log.error("Delete Local Backups Job Permissions Output: " + perOut)
# del files
#delExec = subprocess.Popen(["sudo", "rm", "/var/lib/openhab2/backups/*.*"], stdout=subprocess.PIPE)
delExec = subprocess.Popen(["sudo", "rm", "-fv", "/var/lib/openhab2/backups/*.*"], stdout=subprocess.PIPE)
#delExec = subprocess.Popen(["rm", "/var/lib/openhab2/backups/*.*", "-f"], stdout=subprocess.PIPE)
#delExec = subprocess.Popen(["sudo", "rm", "/var/lib/openhab2/backups/*.*", "-f"], stdout=subprocess.PIPE)
#delExec = subprocess.Popen(["sudo", "rm", "-f", "/var/lib/openhab2/backups/*.*"], stdout=subprocess.PIPE)
delOut, delErr = delExec.communicate()
backup.log.error("Delete Local Backups Job Output: " + delOut)
