michaeljoos
(Michael Joos)
#1
I have started migrating all my rules from ECMA (Nashorn) to new JSScripting. Can someone help me why below test rule doesn’t work anymore?
“console.error(event.itemCommand)” returns:
2021-12-30 18:23:12.011 [ERROR] [org.openhab.automation.script ] - ON
But the If-Statement does not work. Never get a “Test 1” or “Test 2” for command OFF. Tried both:
== ‘ON’
== “ON”
switch (event.itemName){
case "Fernseher" :
if (event.itemCommand == 'ON') {
console.error("Test 1");
} else if (event.itemCommand == 'OFF') {
console.error("Test 2");
michaeljoos
(Michael Joos)
#2
OK, seems that event.itemCommand is a different type.
This works, but not sure if it is the right approach:
var myCommand = String(event.itemCommand);
if (myCommand == "ON") {
// Do something
Doesn’t work:
var myCommand = event.itemCommand;
// Do something
if (myCommand == 'ON') {
// Do something
Any other ideas or comments?
rlkoshak
(Rich Koshak)
#3
"ON"
is a string. So you will want to compare it to a String.
event.itemCommand
is an openHAB Java Command Object, not a String.
So either the Command needs to be come a String, or the String needs to become a Command.
system
(system)
closed
#4
