Today I decided to update my openhab system which originally is based on openhabian from Stretch to Buster.
I did a backup but before going back I’m wondering what might have broken my system during the process since openhab2 does not start correctly anymore.
What I did:
upgraded my system (still on Stretch) via apt-get upgrade (including openhab 2.5.9)
verified this worked and yes, it did
created my backup from the sd card
switched my repos fro stretch to buster and started upgrading
after upgrade used openhabian-config and clicked through some of the items including package install and “apply improvements” and stuff
Now openhab2 does not start correctly and in the logfile there is not much more than:
removed var/lib/openhab2/config/org/openhab/addons.config as I found a hint about that.
The error log entry is gone but now only the following is left:
2020-09-27 17:52:39.359 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'scenes.items'
2020-09-27 17:52:39.711 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'alexa.items'
2020-09-27 17:52:40.020 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'speedtest.items'
2020-09-27 17:52:40.072 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.items'
2020-09-27 17:52:40.670 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2020-09-27 17:52:40.725 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2020-09-27 17:52:41.589 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'klima.sitemap'
2020-09-27 17:52:41.669 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'monitoring.sitemap'
2020-09-27 17:52:41.756 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'steuerung.sitemap'
2020-09-27 17:52:41.817 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'energie.sitemap'
2020-09-27 17:52:42.212 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netatmo.things'
2020-09-27 17:52:45.790 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-09-27 17:54:16.548 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'motion.rules'
2020-09-27 17:54:17.452 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'garage.rules'
2020-09-27 17:54:18.142 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'echo.rules'
2020-09-27 17:54:19.004 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'thermostat.rules'
2020-09-27 17:54:21.213 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'speedtest.rules'
2020-09-27 17:54:25.964 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'scenes.rules'
2020-09-27 17:54:26.463 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'outdoor.rules'
2020-09-27 17:54:26.665 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.rules'
2020-09-27 17:54:27.685 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.rules'
Seems that openhab is not really fully started still but w/o any error in the log. http://openhab:8080/start/index shows a 404 from jetty
