touitoui
(Matthias Herrmann)
October 23, 2021, 7:11pm
#1
recently, when adding points from things to semantic model, my JVM crashes. This is an example log of such a crash: hs_err_pid22071.log (104.7 KB)
As this is most probably not an openhab but an OpenJDK issue, I should probably change JVM vendor. Can you recommend alternatives?
mstormi
(Markus Storm)
October 23, 2021, 9:11pm
#2
Wolfgang_S
(Wolfgang_S)
October 24, 2021, 8:21am
#3
touitoui
(Matthias Herrmann)
October 24, 2021, 8:51am
#4
Platform information:
Hardware: Raspberry Pi 2 Model B Rev 1.1
OS: Raspbian GNU/Linux 10 (buster)
openHABian: openHAB3 Branch
Java Runtime Environment:
openjdk version “11.0.11” 2021-04-20
OpenJDK Runtime Environment AdoptOpenJDK-11.0.11+9 (build 11.0.11+9)
OpenJDK Server VM AdoptOpenJDK-11.0.11+9 (build 11.0.11+9, mixed mod
openHAB version: openHAB 3.1.0
Just tried with AdoptOpenJDK, same symptoms: hs_err_pid15221.log (105.5 KB)
This was just one bugfix version older than my initial jvm, so no wonder. Will try another implementation.
touitoui
(Matthias Herrmann)
October 24, 2021, 12:54pm
#5
Next try, OpenJDK Runtime Environment Zulu11.50+19-CA (11.0.12+7), crashes also, but with a different frame message: hs_err_pid21957.log (109.2 KB)
I’m slowly running out of JVM implementations… The last bigger change to my system was adding the ipcamera binding. Will delete it and try again. Although I don’t have much hope that this is the root cause.
touitoui
(Matthias Herrmann)
October 24, 2021, 12:59pm
#6
org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.getDB is in the stack trace before the crash occurs.
touitoui
(Matthias Herrmann)
October 24, 2021, 1:06pm
#7
Deleting the rrd4j persistence altogether seems to fix it. Fortunately I don’t use rrd4j anyway, so this should work for me.
There has been a problem with RRD4J persistence
<wrong>
in combination with ZRAM</wrong>
(EDIT: According to the GitHub issue, this is not related with ZRAM). In very rare occasions one of the rrd files got corrupted resulting in java crashes:
opened 12:56PM - 30 Dec 20 UTC
external bug
My OH Java (3.0 release as well as latest snapshot) keeps crashing every few min… utes, Java hs_err_pidxxxxx.log below
It's always in rrd4j processing.
At times I saw an error like
2020-12-30 13:19:12.834 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/K_Waschkeller_Thermo_Batterie.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/K_Waschkeller_Thermo_Batterie.rrd] is not a RRD4J RRD file
But it warns of various different item.rrd files it cannot persist into.
And I have already deleted all of my persisted .rrd files in /var/lib/openhab/persistence/rrd4j so Java complains about a file it created itself in those few minutes it ran.
[ EDIT: eventually it did not really "remove" the file because the persistence dir is on ZRAM and what's on disk before ZRAM start then will be used ... complicated to explain but if there's an error in *that* file deleting it doesn't help. ]
Either way, Java must not crash even if the persistence dir is gone or files in there have bad permissions.
# A fatal error has been detected by the Java Runtime Environment:
# SIGBUS (0x7) at pc=0x76ba3d84, pid=16426, tid=17020
# JRE version: OpenJDK Runtime Environment Zulu11.43+88-CA (11.0.9+11) (build 11.0.9+11-LTS)
# Java VM: OpenJDK Client VM Zulu11.43+88-CA (11.0.9+11-LTS, mixed mode, serial gc, linux-arm)
# Problematic frame:
# V [libjvm.so+0x57cd84] _Copy_conjoint_jints_atomic+0x24
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java
again
# If you would like to submit a bug report, please visit:
# http://www.azulsystems.com/support/
--------------- S U M M A R Y ------------
Command Line: -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/run
time -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.cm.dir=/var/lib/openhab/config -Djava.library.path
=/var/lib/openhab/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dnashorn.args=--no-deprecation-warning -Dorg.ops4j.pa
x.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true
-Xms192m -Xmx320m --add-reads=java.xml=java.logging --add-exports=java.base/org.apache.karaf.specs.locator=java.xml,ALL-UNNAMED --pa
tch-module=java.base=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.locator-4.2.7.jar --patch-module=java.xml=/usr/sh
are/openhab/runtime/lib/endorsed/org.apache.karaf.specs.java.xml-4.2.7.jar --add-opens=java.base/java.security=ALL-UNNAMED --add-open
s=java.base/java.net=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=
java.naming/javax.naming.spi=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport.tcp=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNN
AMED --add-opens=java.base/java.lang.reflect=ALL-UNNAMED --add-opens=java.base/java.text=ALL-UNNAMED --add-opens=java.desktop/java.aw
t.font=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.http=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.https=A
LL-UNNAMED --add-exports=java.base/sun.net.www.protocol.jar=ALL-UNNAMED --add-exports=jdk.xml.dom/org.w3c.dom.html=ALL-UNNAMED --add-
exports=jdk.naming.rmi/com.sun.jndi.url.rmi=ALL-UNNAMED -Dkaraf.instances=/var/lib/openhab/tmp/instances -Dkaraf.home=/usr/share/open
hab/runtime -Dkaraf.base=/var/lib/openhab -Dkaraf.data=/var/lib/openhab -Dkaraf.etc=/var/lib/openhab/etc -Dkaraf.log=/var/log/openhab
-Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab/tmp -Djava.util.logging.config.file=/var/lib/openhab/etc/java.u
til.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true org.apache.karaf.main.Main
Host: rev 4 (v7l), 4 cores, 974M, Raspbian GNU/Linux 10 (buster)
Time: Wed Dec 30 13:19:12 2020 CET elapsed time: 123.833624 seconds (0d 0h 2m 3s)
--------------- T H R E A D ---------------
Current thread (0x5bc73c00): JavaThread "OH-items-4" [_thread_in_vm, id=17020, stack(0x55d60000,0x55db0000)]
Stack: [0x55d60000,0x55db0000], sp=0x55dae494, free space=313k
Native frames: (J=compiled Java code, A=aot compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x55dae4bc
J 1637 jdk.internal.misc.Unsafe.copyMemory0(Ljava/lang/Object;JLjava/lang/Object;JJ)V java.base@11.0.9 (0 bytes) @ 0x7458c330 [0x745
8c280+0x000000b0]
J 7917 c1 jdk.internal.misc.Unsafe.copyMemory(Ljava/lang/Object;JLjava/lang/Object;JJ)V java.base@11.0.9 (33 bytes) @ 0x74a08a64 [0x7
4a08860+0x00000204]
j java.nio.DirectByteBuffer.put([BII)Ljava/nio/ByteBuffer;+110 java.base@11.0.9
j java.nio.ByteBuffer.put([B)Ljava/nio/ByteBuffer;+5 java.base@11.0.9
j org.rrd4j.core.RrdNioBackend.write(J[B)V+22
j org.rrd4j.core.RrdBackend.writeString(JLjava/lang/String;I)V+80
j org.rrd4j.core.RrdBackend.writeString(JLjava/lang/String;)V+188
j org.rrd4j.core.RrdPrimitive.writeString(Ljava/lang/String;)V+9
j org.rrd4j.core.RrdString.set(Ljava/lang/String;)V+40
j org.rrd4j.core.Header.<init>(Lorg/rrd4j/core/RrdDb;Lorg/rrd4j/core/RrdDef;)V+135
j org.rrd4j.core.RrdDb.<init>(Lorg/rrd4j/core/RrdDef;Lorg/rrd4j/core/RrdBackendFactory;)V+103
j org.rrd4j.core.RrdDb.<init>(Lorg/rrd4j/core/RrdDef;)V+3
j org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.getDB(Ljava/lang/String;)Lorg/rrd4j/core/RrdDb;+109
j org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.store(Lorg/openhab/core/items/Item;Ljava/lang/String;)V+49
j org.openhab.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(Lorg/openhab/core/items/Item;Z)V+162
j org.openhab.core.persistence.internal.PersistenceManagerImpl.stateChanged(Lorg/openhab/core/items/Item;Lorg/openhab/core/types/Sta
te;Lorg/openhab/core/types/State;)V+3
j org.openhab.core.items.GenericItem.lambda$1(Lorg/openhab/core/items/StateChangeListener;Lorg/openhab/core/types/State;ZLorg/openha
b/core/types/State;)V+17
j org.openhab.core.items.GenericItem$$Lambda$931.run()V+20
J 3982 c1 java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V java.base@11.0.9 (187
bytes) @ 0x74413260 [0x74413020+0x00000240]
j java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5 java.base@11.0.9
j java.lang.Thread.run()V+11 java.base@11.0.9
v ~StubRoutines::call_stub
V [libjvm.so+0x371aec] JavaCalls::call_helper(JavaValue*, methodHandle const&, JavaCallArguments*, Thread*)+0x2b4
V [libjvm.so+0x3702e8] JavaCalls::call_virtual(JavaValue*, Handle, Klass*, Symbol*, Symbol*, Thread*)+0x140
V [libjvm.so+0x412470] thread_entry(JavaThread*, Thread*)+0xa0
V [libjvm.so+0x68d7ac] JavaThread::thread_main_inner()+0xf0
V [libjvm.so+0x68a970] Thread::call_run()+0x158
V [libjvm.so+0x579a4c] thread_native_entry(Thread*)+0x108
C [libpthread.so.0+0x6494] start_thread+0xcc
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J 1637 jdk.internal.misc.Unsafe.copyMemory0(Ljava/lang/Object;JLjava/lang/Object;JJ)V java.base@11.0.9 (0 bytes) @ 0x7458c300 [0x745
8c280+0x00000080]
4a08860+0x00000204]
siginfo: si_signo: 7 (SIGBUS), si_code: 2 (BUS_ADRERR), si_addr: 0x53c7b000
But that’s just a wild guess. But you can compare your logs with the ones from the issues.
However, even if there’s still a bug open, it didn’t happen to me for quite some time and i’m using rrd4j with ZRAM enabled.
touitoui
(Matthias Herrmann)
October 24, 2021, 3:29pm
#9
Does not sound wild at all to me, thanks for pointing that out. Pretty sure it’s the same issue. For me it happened when creating enough items at the same time. Creating just one item was fine.
