[JVM11] Trouble with initial install
MacOs X El Capitan ver 10.11.6
I get the following error when running start.sh
Error installing bundle listed in startup.properties with url: mvn:org.apache.karaf.features/org.apache.karaf.features.extension/4.1.5 and startlevel: 1
Java version:
openjdk version “11.0.1” 2018-10-16 LTS
OpenJDK Runtime Environment Zulu11.2+3 (build 11.0.1+13-LTS)
OpenJDK 64-Bit Server VM Zulu11.2+3 (build 11.0.1+13-LTS, mixed mode)
downgrade to a JVM 8 plz
JVM 11 support is coming but it’s not here yet
Thank for the help. I am new to mac thus not always sure I do the right thing.
I tried was you suggested and this is the result:
gerard-MBP-3:openhab gerardsch$ java -version
java version “1.8.0_191”
Java™ SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot™ 64-Bit Server VM (build 25.191-b12, mixed mode)
gerard-MBP-3:openhab gerardsch$ ./start.sh
Launching the openHAB runtime…
Is there more changes required?
check folder permissions
the OH2 process runs as user openhab and it may not be able to access all files and folders
erard-MBP-3:~ gerardsch$ ls -l
total 0
drwx------+ 4 gerardsch staff 136 Nov 22 21:26 Desktop
drwx------+ 4 gerardsch staff 136 Aug 28 2016 Documents
drwx------+ 15 gerardsch staff 510 Nov 25 14:52 Downloads
drwx------@ 52 gerardsch staff 1768 Aug 28 2016 Library
drwx------+ 3 gerardsch staff 102 Feb 14 2016 Movies
drwx------+ 4 gerardsch staff 136 Feb 21 2016 Music
drwx------+ 4 gerardsch staff 136 Feb 14 2016 Pictures
drwxr-xr-x+ 5 gerardsch staff 170 Feb 14 2016 Public
drwxr-xr-x 20 gerardsch staff 680 Nov 24 17:52 karaf
drwxr-xr-x 11 gerardsch staff 374 Nov 24 11:21 openhab
I am not familiar with Mac… I may be wrong about the permissions …
did you follow the instructions here:
  1. Download openHAB | openHAB
  2. openHAB on macOS | openHAB
Thanks for the effort. Hope someone with mac knowledge will help. I would really like to use this laptop for openhab.
Lets hope!
Dim
Do you think someone else might help me or must I post in a different section?
There will be others to help, I am sure :slight_smile:
This is the right category to ask this type of questions.
Can you try to use the latest Milestone to see if things improve: [OH 2.4.0 M6] Testing Results
remove the existing OH2.3.0 Stable installation, download 2.4.0.M6 and try to start it up
That worked
M7 is out now :slight_smile:
