Running openhabian on Pi4
openHAB 3.4.0 Build #3029
jython rules
I’ve seen the thread regarding this issue and suggestions to not use datetime, but I wanted to add this here anyway since it seems so bizarre.
I use datetime in many modules in the exact same manner as below (well obviously there must be something different, but anyway) … as you can see by the code below, if I declare a global variable datetime becomes <type ‘java.sql.Timestamp’> … without the global it works fine. I saw recommendations to import core.date
… but that made no difference (as the thread said as well)
The weird thing is that I can go back to other code I have and add a global and the problem does not occur. Short of not using datetime, has someone else got around this?
#import core.date
from core.rules import rule
from core.triggers import when
from datetime import datetime
lastDoorClosed1 = None
lastDoorClosed2 = None
from org.slf4j import LoggerFactory
from configuration import LOG_PREFIX
log = LoggerFactory.getLogger("{}.rules testing".format(LOG_PREFIX))
@rule("Test Rule 1")
@when("Item TestButton changed to ON")
def rTestRule1(event):
# global lastDoorClosed1
lastDoorClosed1 = datetime.now()
log.info("Type is correct: lastDoorClosed1=%s, type=%s" % (lastDoorClosed1,type(lastDoorClosed1)))
@rule("Test Rule 2")
def rTestRule2(event):
global lastDoorClosed2
lastDoorClosed2 = datetime.now()
log.info("Type is NOT correct: lastDoorClosed2=%s, type=%s" % (lastDoorClosed2,type(lastDoorClosed2)))
2022-11-08 15:38:15.443 [INFO ] [jsr223.jython.rules testing ] - Type is correct: lastDoorClosed1=2022-11-08 15:38:15.438000, type=<class 'datetime.datetime'>
2022-11-08 15:38:15.447 [INFO ] [jsr223.jython.rules testing ] - Type is NOT correct: lastDoorClosed2=2022-11-08 07:38:15.443, type=<type 'java.sql.Timestamp'>
