I did exactly the same as you and everything works fine, so that should be a solvable problem…
What exactly is line 7 in your rule file?
And just to be sure and because I sometimes make this mistake myself: Are you sure, that you edited the correct file? Maybe you have changed the file in /etc/openhab2 and not /etc/openhab, e.g. because a network share still points to the old location?
The hello_world.py example script, and all the other example scripts have not received updates for OH3.
Give the lack of activity on the main Helper Libraries repo, I have started maintaining my own fork with updates to make them compatible with OH3 among other things. The example scripts have not been updated their either, but the libraries have been tested to work with OH3.
In that case you are not running the oh3-patch branch that you think you are. Look at my post that I linked, you will find notes on installing in OH3 and a link to my fork where you will not need to checkout a different branch to get the updates.
Hi Ivan,
thank you. With your fork that worked for me!
I thought that oh3-patch had all neccessary adjustments, but seems that there are still issues.
Thank you for your support!
That oh3-patch branch does have all necessary changes, I checked and updated it and then used those changes in my fork. I think maybe you had not checked out the branch when you copied the files to your installation.
Regardless, it is now outdated and you should use my fork until the main repo becomes active again and I get everything merged back.
That screenshot is, I exclusively use VSCode now. There are other Python code highlighters and autocompletion tools though, I just don’t know what is available for Eclipse.
If you do choose to get that setup for Eclipse, please consider submitting instructions for that to the stubs repo!
Hi Ivan,
first rules are working, great!
Now I want to to start implementing a rule with the telegram binding. Therefore I try to import the lib to my code:
from core.actions import Telegram
But there was an error:
ImportError: cannot import name Telegram in at line number 3
@japhias looks like you are trying using the OH1.x Telegram binding action. In OH3 Telegram is using the new style Thing Actions. There are other examples of the MQTT2 binding if you want more examples, here is what you need for Telegram.
Is this manual patch still required? If so, any plans or threads about getting OH3 Jython working officially?
I didn’t add the patch yet, but I added the Jython Automation Add-on via: ->Settings->Automation->+ -> Jython Scripting, and am seeing errors with my 2.5 jython scripts, so guessing the patch is still needed…
This patch is not for Jython itself. It is for the jython helper libraries. It is required if you use the jython helper libraries. You can use Jython without the helper libraries if you like.
I’m seeing these errors upon startup - Should these files be deleted or did I do something wrong? I admit I’m very hazy on the install - I came from OH2.5, then copied over your patch on top of what I already had (perhaps this is wrong).
Side note, anyway we can “easily” change this error to something more meaningful (this is maybe incorrect, but error that instead says “Method or Import does not exist”). I"m not sure if this can be done in the helper libraries or has to be done in openhab core…
Thanks!
2021-03-11 12:17:21.830 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/100_OsgiEventTrigger.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2021-03-11 12:17:21.833 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/100_StartupTrigger.py'
2021-03-11 12:17:22.465 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py'
2021-03-11 12:17:22.928 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2021-03-11 12:17:22.929 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonExtensionProvider.py'
2021-03-11 12:17:23.413 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonExtensionProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2021-03-11 12:17:23.415 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py'
2021-03-11 12:17:23.893 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2021-03-11 12:17:23.895 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonItemProvider.py'
2021-03-11 12:17:24.334 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonItemProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2021-03-11 12:17:24.335 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonThingProvider.py'
2021-03-11 12:17:24.778 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonThingProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2021-03-11 12:17:24.780 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py'
2021-03-11 12:17:25.201 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2021-03-11 12:17:25.202 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/etc/openhab/automation/jsr223/python/core/components/200_JythonTransform.py'
2021-03-11 12:17:25.676 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/core/components/200_JythonTransform.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 7
Looks like you have leftover files from an older version. Wipe everything in automation/jsr223/core and automation/lib/core then follow the install instructions here Ivan’s Helper Libraries - OH3, Python, JavaScript
