Hi everyone,
while testing my new Jython rules I observed a strange behavior. I am not sure if this might be a bug in my rule, I just can’t see or in the jsr223 subsystem or if this behavior is normal and to be expected.
I have an item to retrieve the downloaded data volume from my internet router, using the snmp binding. This item is updated every 10 minutes. In addition I have a rule, that triggers when this item is changed and calculates daily and monthly values. In this rule I compare the current value to the maximum value of the last 15min to be notified when the router resets the value. This only happens when the router is restarted, so the current value should not be smaller than the maximum of the last 15 min.
Since using the new Jython rule I get the “counter reset” warning message once or twice a day, I never had this with the old DSL rule. When I compare the logs of my rules and the openhab event log, it seems, that the “items[]” dictionary I use to retrieve the current value, after the rule has been triggered, has not been updated when the rule is triggered.
So the the question probably is, if it is to be expected, that the items[] dictionary might be updated too late and therefor only the event.itemState variable should be used. Would this variable always hold the correct current value?
Here is an except from the rule:
@rule("Update VDSL transfer statistics - Jython")
@when("Item Network_Router_RX_Count received update")
def updateVDSLTransferStatistics(event):
if items['SystemReady'] != OnOffType.ON:
return
rxCount = items['Network_Router_RX_Count']
rxMinDaily = getMinimumSince('Network_Router_RX_Count', DateTime.now().withTimeAtStartOfDay())
rxMinMonthly = getMinimumSince('Network_Router_RX_Count', DateTime.now().withTimeAtStartOfDay().withDayOfMonth(1))
txCount = items['Network_Router_TX_Count']
txMinDaily = getMinimumSince('Network_Router_TX_Count', DateTime.now().withTimeAtStartOfDay())
txMinMonthly = getMinimumSince('Network_Router_TX_Count', DateTime.now().withTimeAtStartOfDay().withDayOfMonth(1))
rxMax15min = getMaximumSince('Network_Router_RX_Count', DateTime.now().minusMinutes(15))
log.info("Router statistics debug: rxCount.longValue(): " + str(rxCount.longValue()) + " rxMax15min.longValue() " + str(rxMax15min.longValue()))
if rxCount not in [NULL, UNDEF] and rxMinDaily not in [NULL, UNDEF] and rxMinMonthly not in [NULL, UNDEF] and rxMax15min not in [NULL, UNDEF]:
RouterRxDaily = rxCount.longValue() - rxMinDaily.longValue()
RouterRxMonthly = rxCount.longValue() - rxMinMonthly.longValue()
# Counter reset
if rxCount.longValue() < rxMax15min.longValue():
log.info("Network Router Rx Counter reset")
Here the log entry from the rule, the current value is lower than the maximum of the last 15 min:
2019-01-13 21:32:54.125 [INFO ] [marthome.automation.network_rules.py] - Router statistics debug: rxCount.longValue(): 141636882180 rxMax15min.longValue() 141656257434
This is the event log:
2019-01-13 21:32:54.110 [vent.ItemStateChangedEvent] - Network_Router_RX_Count changed from 141636882180 to 141656257434
I still have the old DSL rule running in parallel, without modifying any values, this rule logs the correct value:
2019-01-13 21:32:54.170 [INFO ] [smarthome.model.script.network rules] - Router statistics updated: RX-Count: 141656257434 - TX-Count: 9423035786
The getMinimumSince() and getMaximumSince Functions are two small functions I wrote just for better readability:
def getMinimumSince(item, time):
return PersistenceExtensions.minimumSince(itemRegistry.getItem(item), time).state
def getMaximumSince(item, time):
return PersistenceExtensions.maximumSince(itemRegistry.getItem(item), time).state
Thanks for your help!
Juelicher
