Hi there,
i´m in the process of implementing moisture monitoring. To do this, i put all my moisture sensors (tado) together in a group and created a dummy switch.
As soon as an item rises above 60% humidity, the dummy switch should go to ON - the following script is used for this:
from core.rules import rule
from core.triggers import when
@rule("rule_humidity")
@when("Member of group_humidity changed")
def check_humidity(event):
humidity = event.itemName
if items[humidity] > 50:
events.sendCommand("dummy_humidity", "ON")
However, where i have problems is how can i now check whether ALL items in a group have the status of below 60% humidity, because only then should the dummy switch go to OFF.
Of course, i could query each item individually and only switch the dummy switch to OFF as soon as the condition is met, but i think there should also be the possibility of solving this via the group.
Thanks in advance!
Christoph
