Hi
I just moved my rules from rules DSL to Jython and I have a few questions that I would like to ask.
- I cant get
@when("System started")
to work, jython script:
from openhab.rules import rule
from openhab.triggers import when
@rule("Initial setup")
def initialSetupRule(event):
log.debug("JSR223: System started.")
createTimer( DateTime.now().plusMinutes( 1 ), initialSetup )
Error that I get:
[ERROR] [omation.core.internal.RuleEngineImpl] - @when: Exception [@when: "System started" could not be parsed because rule triggers do not currently support target_type "System"]: [Traceback (most recent call last):
File "/etc/openhab2/automation/lib/python/openhab/triggers.py", line 333, in when
raise ValueError("@when: \"{}\" could not be parsed because rule triggers do not currently support target_type \"System\"".format(target))
ValueError: @when: "System started" could not be parsed because rule triggers do not currently support target_type "System"
[ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab2/automation/jsr223/coop_rules.py': TypeError: 'NoneType' object is not callable in <script> at line number 100
And looking here it should be working
I have uC (microcontroller) that I want âtalkâ to via i2c, I got this part working in Python before I even started with OpenHAB. Before I switched to Jython I got advised here the best option would be to run my uC script as a service sort of independent of OH because I want every X seconds read data from it and send data to it when some OH rules are triggered. Since I have now switched to Jython wouldnât it be better to just import my uC class (with all i2c methods) from that script and call them in cron rule?
JSR223 and Jython. I would like to know if I understood everything right. JSR223 is a âfunctionalityâ that lets other scripting languages comunicate with Java (objects/classes/etc) and Jython is just Python using those âJava thingsâ, right? So
Jython = JSR223
butJSR223 â Jython
