RJGhugo
(RjGhugo)
January 13, 2021, 8:57pm
#1
Platform information:
Hardware: ARM/8GB RAM/128 USB
OS: Ubuntu 20.10 Server/64bit, k3s
Java Runtime Environment: included in Docker Image
openHAB version: 3.x
Issue of the topic: deploy openHAB on k3s
The Pod does not get connected to the metallb ip (192.168.188.83). Cannot scan for items in the network (192.168.188.x).
Please post configurations (if applicable):
apiVersion: v1
kind: PersistentVolume
metadata:
labels:
type: local
spec:
storageClassName: manual
capacity:
storage: 5Gi
accessModes:
- ReadWriteOnce
hostPath:
path: "/home/mtw/daten/openhab"
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 5Gi
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: openhab
spec:
replicas: 1
selector:
matchLabels:
app: openhab
template:
metadata:
labels:
app: openhab
spec:
containers:
- name: openhab
image: openhab/openhab
ports:
- containerPort: 8080
protocol: TCP
- containerPort: 8443
protocol: TCP
- containerPort: 8101
protocol: TCP
volumeMounts:
- name: etc-localtime
mountPath: /etc/localtime
readOnly: true
- name: openhab
mountPath: /openhab/conf
subPath: conf
readOnly: false
- name: openhab
mountPath: /openhab/userdata
subPath: userdata
readOnly: false
- name: openhab
mountPath: /openhab/addons
subPath: addons
readOnly: false
- name: openhab
mountPath: /openhab/.java
subPath: java
readOnly: false
- name: openhab
mountPath: /openhab/.karaf
subPath: karaf
readOnly: false
volumes:
hostPath:
path: /usr/share/zoneinfo/Europe/Berlin
- name: openhab
persistentVolumeClaim:
claimName: pv-openhab
apiVersion: v1
kind: Service
metadata:
spec:
selector:
app: openhab
ports:
- protocol: TCP
port: 8080
targetPort: http
- protocol: TCP
port: 8443
targetPort: https
- protocol: TCP
port: 8101
targetPort: console
type: LoadBalancer
loadBalancerIP: 192.168.188.83
Items configuration related to the issue
metallb ip reserved for openHAB (192.168.188.83)
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
RJGhugo
(RjGhugo)
January 14, 2021, 12:46pm
#2
allow firewall to see UPnP devices
use hostNetwork: true (Workaround, preferable LoadBalancer)
apiVersion: v1
metadata:
labels:
type: local
spec:
capacity:
storage: 5Gi
accessModes:
- ReadWriteOnce
hostPath:
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 5Gi
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: openhab
spec:
replicas: 1
selector:
matchLabels:
app: openhab
template:
metadata:
labels:
app: openhab
spec:
hostNetwork: true
containers:
- name: openhab
ports:
protocol: TCP
protocol: TCP
protocol: TCP
volumeMounts:
readOnly: true
- name: openhab
subPath: conf
readOnly: false
- name: openhab
subPath: userdata
readOnly: false
- name: openhab
subPath: addons
readOnly: false
- name: openhab
subPath: java
readOnly: false
- name: openhab
subPath: karaf
readOnly: false
volumes:
hostPath:
- name: openhab
RJGhugo
(RjGhugo)
January 27, 2021, 8:48am
#3
Problem with the OpenHAB time!
This seems to solve it:
env:
- name: "TZ"
value: "Europe/Berlin"
volumeMounts:
- name: etc-timezone
mountPath: /etc/timezone
volumes:
hostPath:
hostPath:
→ Settings/Regional Settings → no TimeZone (The underlying system’s time zone is the default.)
how would you access the items files etc. I am using Longhorn for persistent storage. I guess I need to add a samba container to the pod?
RJGhugo
(RjGhugo)
May 19, 2021, 8:18am
#5
Hello Geert,
my configs are here:
- name: openhab
Greetings
