Stupid question, but I’m stuck - how to use grep
in new version?
When i hit Enter - new line appears and i dont know how to run command.
openhab> log:tail | grep 'Rule
quote>
quote>
quote> '
in new version?
quote>
quote>
quote> '
Huh? If you open quotes (a single ’ ) you need to close them (second ’ ) before the command is accepted. It’s always been like that.
I don’t know know to explane that, when i hit enter quotes go to next line - here is video
how did you create both quote chars in one go? Try to enter both of them manually.
If i create one, second appears automatically, and i can not move cursor over it to the right.
Don’t use
instead use
with SHIFT key and hit the sign twice.
Ever tried to nevertheless enter another ’ ?
Yes… openhab> log:tail | grep ‘123’ now it runs, but grep not works.
I try any symbols in quotes, still show whole logs entries.
This is crazy
When i hit ctrl-c:
16:56:08.098 [INFO ] [smarthome.event.ItemStateChangedEvent] - Device_SDM120_PowerFactor changed from 0.86 to 0.85
16:56:08.372 [INFO ] [smarthome.event.ItemStateChangedEvent] - Device_Zbox_Temp changed from 56.0 to 57.0
grep: java.nio.channels.ClosedByInterruptException
^Copenhab>
shows exception
Quotes should be equal single quote chars: '123'
(Jung’, sorry aber dat is’ Englisch!)
Or use none at all if you don’t need to grep for whitespaces, or just grep from the (Juuuhnicks) shell.
Seriously, if you still feel this to be an error, open a Github issue with the ESH project, please (or even Karaf maybe? I guess they’ll tell you if so).
UUAAAA! Thanks a lot! This made me nuts for about one hour!
