today i tried to add my items in myopenhab cloud. its not working. so i try to fix all log errors.
the most errors i fixes, except this:
[WARNUNG] [org.apache.karaf.main.KarafActivatorManager] - Error starting karaf activator org.apache.karaf.specs.activator.Activator from url jar:file:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.specs.activator-4.2.2.jar!/META-INF/MANIFEST.MF
java.lang.NoClassDefFoundError: org/apache/karaf/specs/locator/OsgiLocator
at org.apache.karaf.specs.activator.Activator.register(Activator.java:124)
at org.apache.karaf.specs.activator.Activator.start(Activator.java:71)
at org.apache.karaf.main.KarafActivatorManager.startKarafActivators(KarafActivatorManager.java:62)
at org.apache.karaf.main.Main.launch(Main.java:281)
at org.apache.karaf.main.Main.main(Main.java:178)
Caused by: java.lang.ClassNotFoundException: org.apache.karaf.specs.locator.OsgiLocator
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:583)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
… 5 more
I dont know how i can fix it. May anyone know, what works wrong?
Info:
Openhab2: openHAB 2.5.0.M1 Milestone Build
Java:
openjdk version “11.0.3” 2019-04-16
OpenJDK Runtime Environment (build 11.0.3+7-post-Debian-5bpo91)
OpenJDK 64-Bit Server VM (build 11.0.3+7-post-Debian-5bpo91, mixed mode, sharing)
Linux Debian: Linux version 4.9.0-9-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP Debian 4.9.168-1+deb9u3 (2019-06-16)
2019-07-09 20:48:37.392 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/events
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_2,3,678586690) has been shut down
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.Server.handle(Server.java:503) ~[84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:364) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:411) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:305) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:159) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683) [87:org.eclipse.jetty.util:9.4.12.v20180830]
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1340) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1242) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 19 more
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions. They are:
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 19 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_2,3,678586690) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
… 19 more
now i have only one problem. i try to connect myopenhab for alexa voice. but my alexa app dont find any items. i dont have items in myopenhab too. in the last tutorial this was my breaking point, to solve errors in my logs.
should i open a new thread for this or may you know, what i have to do to fix this?
