Hello
I am running openhab 2.4 snapshot 1458
i dont where to post the messages i get
i get following messages :
openhab> Native code library failed to load.
java.lang.UnsatisfiedLinkError: no tinyb in java.library.path
org.apache.karaf.features.internal.util.MultiException: Error restarting bundles:
Error loading bundle activator.
Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1005)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1025)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:964)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Suppressed: org.osgi.framework.BundleException: Error loading bundle activator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402)
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:161)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1116)
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:997)
… 6 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.openhab.ui.cometvisu (266).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:112)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:984)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427)
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381)
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263)
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196)
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169)
at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:139)
at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:49)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.start(Module.java:467)
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:474)
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:1)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:472)
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:750)
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:741)
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511)
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457)
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1001)
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1382)
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: org.osgi.framework.BundleException: Exception in org.openhab.ui.cometvisu.internal.CvActivator.start() of bundle org.openhab.ui.cometvisu.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103)
… 54 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.glassfish.jersey.media.sse.SseFeature
at org.openhab.ui.cometvisu.internal.CvActivator.start(CvActivator.java:43)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
… 64 more
Suppressed: org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
… 6 more
at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:49)
… 16 more
2018-12-11 20:27:49,637 safeCall-13 ERROR Unable to move file D:\openhab2\userdata\logs\events.log to D:\openhab2\userdata\logs\events.log.7: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log → D:\openhab2\userdata\logs\events.log.7: Het proces heeft geen toegang tot het bestand omdat het door een ander
proces wordt gebruikt.
2018-12-11 20:27:49,887 safeCall-13 ERROR Unable to delete file D:\openhab2\userdata\logs\events.log: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log: Het proces heeft geen toegang tot het bestand omdat het door een ander
2018-12-11 20:27:51,148 safeCall-14 ERROR Unable to move file D:\openhab2\userdata\logs\events.log to D:\openhab2\userdata\logs\events.log.7: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log → D:\openhab2\userdata\logs\events.log.7: Het proces heeft geen toegang tot het bestand omdat het door een ander
2018-12-11 20:27:51,277 safeCall-14 ERROR Unable to delete file D:\openhab2\userdata\logs\events.log: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log: Het proces heeft geen toegang tot het bestand omdat het door een ander
2018-12-11 20:27:52,410 safeCall-12 ERROR Unable to move file D:\openhab2\userdata\logs\events.log to D:\openhab2\userdata\logs\events.log.7: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log → D:\openhab2\userdata\logs\events.log.7: Het proces heeft geen toegang tot het bestand omdat het door een ander
2018-12-11 20:27:52,442 safeCall-12 ERROR Unable to delete file D:\openhab2\userdata\logs\events.log: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log: Het proces heeft geen toegang tot het bestand omdat het door een ander
2018-12-11 20:27:53,183 safeCall-15 ERROR Unable to move file D:\openhab2\userdata\logs\events.log to D:\openhab2\userdata\logs\events.log.7: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log → D:\openhab2\userdata\logs\events.log.7: Het proces heeft geen toegang tot het bestand omdat het door een ander
2018-12-11 20:27:53,246 safeCall-15 ERROR Unable to delete file D:\openhab2\userdata\logs\events.log: java.nio.file.FileSystemException D:\openhab2\userdata\logs\events.log: Het proces heeft geen toegang tot het bestand omdat het door een ander
SLF4J: Failed toString() invocation on an object of type [org.eclipse.smarthome.core.items.events.ItemStateChangedEvent]
Reported exception:
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Arrays.java:3332)
at java.lang.AbstractStringBuilder.ensureCapacityInternal(AbstractStringBuilder.java:124)
at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:448)
at java.lang.StringBuilder.append(StringBuilder.java:136)
at java.lang.StringBuilder.append(StringBuilder.java:76)
at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:484)
at java.lang.StringBuilder.append(StringBuilder.java:166)
at java.util.Formatter$FormatSpecifier.print(Formatter.java:2913)
at java.util.Formatter$FormatSpecifier.printString(Formatter.java:2886)
at java.util.Formatter$FormatSpecifier.print(Formatter.java:2763)
at java.util.Formatter.format(Formatter.java:2520)
at java.util.Formatter.format(Formatter.java:2455)
at java.lang.String.format(String.java:2940)
at org.eclipse.smarthome.core.items.events.ItemStateChangedEvent.toString(ItemStateChangedEvent.java:89)
at org.slf4j.helpers.MessageFormatter.safeObjectAppend(MessageFormatter.java:299)
at org.slf4j.helpers.MessageFormatter.deeplyAppendParameter(MessageFormatter.java:271)
at org.slf4j.helpers.MessageFormatter.arrayFormat(MessageFormatter.java:233)
at org.slf4j.helpers.MessageFormatter.arrayFormat(MessageFormatter.java:173)
at org.slf4j.helpers.MessageFormatter.format(MessageFormatter.java:124)
at org.ops4j.pax.logging.slf4j.Slf4jLogger.info(Slf4jLogger.java:494)
at org.eclipse.smarthome.io.monitor.internal.EventLogger.receive(EventLogger.java:53)
at sun.reflect.GeneratedMethodAccessor14.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153)
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53)
Exception in thread “ESH-OSGiEventManager” java.lang.OutOfMemoryError: Java heap space
openhab>
