I had an Openhab 2.2 installation running on a Pi3 - this run for quite some time.
After the upgrade to 2.3 the dashboard is down (including everything else). So I can’t reach any of the Openhab related services; Grafana for example is working.
The log wasn’t written for a long time but via navigating though several posts I was able to get ‘something’ back - and thats where I’m stuck currently.
So the log shows just this:
2018-05-29 22:24:02.272 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
java.io.IOException: Unexpected end of input at 1:1
at org.apache.karaf.features.internal.util.JsonReader.error(JsonReader.java:337) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.util.JsonReader.expected(JsonReader.java:331) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.util.JsonReader.readValue(JsonReader.java:93) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.util.JsonReader.parse(JsonReader.java:58) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.util.JsonReader.read(JsonReader.java:52) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.region.DigraphHelper.readDigraph(DigraphHelper.java:90) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.region.DigraphHelper.loadDigraph(DigraphHelper.java:70) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:131) [10:org.apache.karaf.features.core:4.1.5]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:242) [10:org.apache.karaf.features.core:4.1.5]
Although its just a warning its the only thing that points to an issue
openhab-cli info provides this:
Version: 2.3.0 (Build)
User: openhab (Active Process 450)
User Groups: openhab tty dialout audio bluetooth gpio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhabian
OPENHAB_CONF | /etc/openhab2 | openhab:openhabian
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhabian
URLs: http://192.168.1.5:8080
https://192.168.1.5:8443
I have no idea where to start looking currently. I ran the manual installer several times but without success.
As mentioned none of the URLs is reachable - although the service is running.
Any ideas
