Just ordered a Kasa HS200 Smart Switch to replace a dead Insteon switch.
My now defunct Insteon switch was automatically turned on and off via openhab pre-sunset and post-sunrise furthermore I was able to control it via Alexa thru the use of the Hue emulation and I do not use openHAB cloud due to internet reliability.
I would like to do that with the Kasa switch. Any advice or instructions?
If openHAB was sending ON/OFF commands to your Insteon switch, then it can send the same to your Kasa switch. Just add the Kasa via the TP-Link binding, then do one of the following:
Make an item for the Kasa switch and substitute that item into any rules where you called the dead Insteon switch.
Edit the existing item for the dead Insteon switch to connect it to the Kasa thing. This way, you don’t have to edit any rules.
Your post wasn’t really clear, all I was pointing out was that any use of alexa is cloud dependent, so why exclude the openhab cloud service if you want to use alexa?
There is a binding specifically for the kasa/tp-link switches and other devices. It is a direct api call, not cloud dependent, and works like a charm. No cloud required.
The Kasa switch that replaced the dead Insteon is being controlled by Alexa because I gave it the same name and made no changes with Alexa locating new smart devices.
It’s been a long time since I had Alexa discover my new devices and I’m not looking to create more trouble for myself. I don’t remember if it adds things wholesale or allow you to pick what you want to add to Alexa when you put things into discovery mode.
I am wondering if the HUE emulation and/or Alexa will freakout break when I try to discover new devices now that my switch named Garage Door Light in no longer an Insteon device but a tp-link device and using different means of communication.
I don’t use Alexa, but it’s only going to see the items that you tag as HUE devices. If you remove the item (or even just the tag), I would assume that the item will disappear when you sync Alexa with HUE. That’s what happens with Google Assistant.
Whatever the case, it shouldn’t be difficult to add/remove a single item from Alexa. People do that all of the time.
Again, HUE and Alexa don’t have any idea about Insteon or TP-Link, because openHAB is telling them that:
openHAB is a HUE hub (via HUE emulation)
The devices you’ve tagged are HUE devices
openHAB doesn’t pass on any more information than, “you can tell this device to turn on and off”.
