I´m using KEBA Binding 2.5.0 with Openhabian 2.5.2-1 on a Raspberry.
As my Wlan-Repeater have troubles to hold connection to my FritzBox, the Keba-thing shows connection-error and does not work anymore. I need to disable and enable the thing to bring it to work again.
Is there any way to restart the thing automatically after loosing kontakt - and shouldn´t it be normal, that the binding tries to connect again after loosing kontak?
Got a solution by using rules:
rule “Refresh_Connection”
Thing “keba:kecontact:095e5da8” changed or System started
var Tstatus = getThingStatusInfo(“keba:kecontact:095e5da8”).getStatus()
if (Tstatus.toString == “OFFLINE”)
createTimer(now.plusSeconds(10), [ |
sendHttpPutRequest(“http://192.168.1.36:8080/rest/things/keba:kecontact:095e5da8/enable”, “application/json”, ‘false’)])
createTimer(now.plusSeconds(30), [ |
sendHttpPutRequest(“http://192.168.1.36:8080/rest/things/keba:kecontact:095e5da8/enable”, “application/json”, ‘true’)])
Thanks to all helpers
