I hope someone can help me with my problem…
I’m using openhab since a couple of years, but on friday I did a systemupdate via openhabian-config (just pulled the latest software, no upgrade to testing-branch or something else). When the openhab2-service was restartet (an update of java caused it) all my things were gone. All items still there, but no more things, the inbox found some things I had used. After rebooting the whole raspi the same result.
“No Problem” I thought to myself “you have your card-backups for that”.
Before updating I shut down the raspi, pull out the card, put it into an sdcard-reader at the laptop und do a full backup with
sudo dd bs=512 status=progress if=/dev/sdb conv=sync,noerror count=14811135 | gzip -c | sudo dd of=/home/ronaldo/Openhabian_Backup_datexyz.img.zip
put the card back into the raspi und it boots normally.
Now I wrote back the last image to the card (with dd and with etcher) and after booting it I got a kernel panic.
Trying another card (probably its corrupt)… same result… tried the backup before the last (on both cards)… same result.
I used google and tried out some things but now I’m at the end… so hopefully someone can lead me.
Both partitions (boot and rootfs) seem to be normal (all files should be there).
[ronaldo@RonaldosPC ~]$ sudo fsck -y /dev/sdb1
fsck von util-linux 2.36.1
fsck.fat 4.1 (2017-01-24)
/dev/sdb1: 217 files, 45733/84261 clusters
The first time after writing the card it says only, that it was not unmounted correctly.
[ronaldo@RonaldosPC ~]$ sudo fsck -y /dev/sdb2
e2fsck 1.45.6 (20-Mar-2020)
rootfs: sauber, 115686/473280 Dateien, 1372877/1939456 Blöcke
[ronaldo@RonaldosPC ~]$ sudo blkid
/dev/sdb1: LABEL_FATBOOT="boot" LABEL="boot" UUID="5DB0-971B" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="5e962008-01"
/dev/sdb2: LABEL="rootfs" UUID="060b57a8-62bd-4d48-a471-0d28466d1fbb" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="5e962008-02"
The cmdline.txt on /boot looks like:
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=5e962008-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Is it possible to rescue the image without setting up all from the beginning?
- Platform information:
- Hardware: Raspi 3B
- OS: OpenHabian
- openHAB version: 2.5.9 (backup before the last one) / 2.5.10 (last backup)
