KLAFS sauna binding
I’m considering writing a binding for KLAFS saunas. They offer a Wi-Fi module that connects to the manufacturers clould service. One can then us a mobile app or https://sauna-app.klafs.com to control the sauna.
Clients use a simple REST API to interact with the service. You first need to login to obtain a token (cookie) and then can query the current status with:
curl -vL https://sauna-app.klafs.com/Account/Login -H "Content-Type: application/x-www-form-urlencoded" --data "UserName=userid&Password=secret" --cookie-jar cookie.txt
curl -v --cookie cookie.txt https://sauna-app.klafs.com/Control/GetSaunaStatus -H "Content-Type: application/json" --data '{"saunaId":"364cc9db-86f1-49d1-86cd-f6ef9b20a490"}'
    "saunaId": "364cc9db-86f1-49d1-86cd-f6ef9b20a490",
    "saunaSelected": false,
    "sanariumSelected": true,
    "irSelected": false,
    "selectedSaunaTemperature": 90,
    "selectedSanariumTemperature": 70,
    "selectedIrTemperature": 100,
    "selectedHumLevel": 7,
    "selectedIrLevel": 3,
    "selectedHour": 12,
    "selectedMinute": 40,
    "isConnected": false,
    "isPoweredOn": false,
    "isReadyForUse": false,
    "currentTemperature": 18,
    "currentHumidity": 0,
    "statusCode": 2,
    "statusMessage": null,
    "showBathingHour": false,
    "bathingHours": 0,
    "bathingMinutes": 0,
    "currentHumidityStatus": 0,
    "currentTemperatureStatus": 0
So I probably need a bridge for storing the account credentials and a thing for the sauna itself.
Which exsiting binding would be a good template that I could clone and adapt?
Norbert
No, even a Thing can store the account credentials, don’t need to be a bridge.
I wouldn’t implement a binding but use the HTTP binding.
How would you handle the authentication scheme with the HTTP binding?
You can substitute any curl command with an http item or you can write a rule, that’ll give you more choices. I have implemented control of my lawn mower using the Web/JSON API and commands like sendHttpPostRequest(URL, "application/x-www-form-urlencoded", jsondata).
There can be multiple saunas attached to a single account. That’s why I thought of having a bridge.
Ah, I see. In that case, a Bridge is indeed needed.
According to the JavaDoc for sendHttpPostRequest this method only returns the response body as a string. To get the access token, I need access to the response headers for the cookie (and the Location header for automatic thing discovery).
Hi nklasen,
I am at the same point, with curl in a rule. curl delivering expected json in command shell, but full download header (“% Total % Received…”) when used in executeCommandLine.
Btw. same for curl requesting session cookie. Workarounded this by requesting cookie once via shell command to /tmp/cookie.txt for being used during json request. Could be placed elsewhere to survive a reboot or clean-cache. Not nice, yet working.
Should work to use same concept for json query, with curl-command in script file to be triggered by executeCommandLine, relaying the curl command from the executeCommandLine, but would be workaround squared and not sure how to read output file for json transformation.
Found myself locked out of manufacturer’s webservice after I tried to request cookie with any json query. Needed to contact their customer support to get accout reset.
Was there any further findings on your end since end May?
sendHttpPostRequest doesn’t allow cookie.txt input, correct?
Hi Carl,
Yes, sendHttpPostRequest not providing access to header prevents the HTTP action from being used.
I’ve looked at a few other bindings that implement a bridge which connects to a cloud service but other than that, I haven’t spend much time on the subject since. Do you have any suggestions which binding to use as a blue print?
Norbert
Hi Norbert,
bindings “tankerkönig” or “gardena” might make some sense. Both use bridges, connect to a web/cloud service and I see that at least tankerkönig takes json response after sending a token “apikey”. Yet, this is an agreed and constant value. KLAFS cookie needs renewal after unsuccessful query. But not too often, for not getting blocked as I was. And cookie is not a token.
openweathermap should be comparable to the above.
Gardena binding might also be helpful as I read (and see myself) that its usage kicks out mobile app. A temporary client-based token or cookie seems to be taken by the binding, not allowing the mobile app to enter without login credentials.
Carl.
Is there a use case for multiple saunas? Do many people have multiple saunas on their property? Just curious…
Hi Maurits28,
despite the fact that Klafs’ sauna management simply allows multiple saunas per account, I see 2 use cases: 1. hotel type case with 2-3 saunas in their spa, as Klafs app is more a remote control than allowing elevated smart options e.g. repetitive calendared switching; 2. single maintainer of multiple private saunas, which in fact don’t need to be in single property, but e.g. spread over houses of different family members.
I admit these might not reflect the majority in sauna/openHAB use cases, thus a major argument for openHAB in scenarios which didn’t take this platform into account yet. It supersedes options of native Klafs app.
Other bindings answered similar question pro-bridge, e.g. Gardena.
Best,
Carl.
Makes sense what you’re saying. Indeed probably few openHAB users with this need. Good luck with your automation!
Hi Alexander,
I haven’t had the time to explore this any further.
Regards
Norbert
It looks like someone has already reverse-engineered the REST API used by the Klafs app and developed an interface for IP-Symcon:
:backhand_index_pointing_right: GitHub - Pommespanzer/IPSymconKlafsSaunaControl
Is there still interest in working on an openHAB binding for Klafs?
With the API decoded, anyone can well use the HTTP binding. Probably a more effective approach that to start writing a binding (unless you want to for an exercise).
While the API has been decoded, you’d still need to reverse-engineer the IP Symcon module and manually configure all the HTTP calls. Given that, I’d argue a dedicated binding could be more effective and user-friendly—at least if there’s sufficient interest.
OH is a community effort.
If you want to take on it, feel free.
But don’t forget you will also have to maintain your binding.
Yes, that’s exactly why I was asking if anyone else is interested in working on it. I currently have too many other development commitments to take it on alone, but I’d be happy to contribute as part of a collaborative effort.
