KM200 Empty Channel List
I have connected OpenHAB 3.1 to my KM100. The communication with the device is established (correct privKey) and the device appears as “online”. Sadly, the channel list is empty (there are quite a lot of items detected in the log, though). Any hints? Thanks.
Log part 1:
[internal.handler.KM200GatewayHandler] - Update KM50/100/200 gateway configuration, it takes a minute....
[internal.handler.KM200GatewayHandler] - Set read delay to: 100 seconds.
[internal.handler.KM200GatewayHandler] - Set refresh interval to: 30 seconds.
[internal.handler.KM200GatewayHandler] - Set max. number of repeats to: 10 seconds.
[hab.binding.km200.internal.KM200Comm] - Starting receive connection...
[internal.handler.KM200GatewayHandler] - Test of the communication to the gateway was successful..
[internal.handler.KM200ServiceHandler] - Blacklisted: /gateway/firmware
[b.binding.km200.internal.KM200Device] - Communication to /systemStates is not possible!
[internal.handler.KM200ServiceHandler] - initDevice: nodeRoot == null for service: /systemStates
[l.handler.KM200VirtualServiceHandler] - Full Servicename: /dhwCircuits/dhw1/switchPrograms/A
[ler.KM200SwitchProgramServiceHandler] - Positive switch: off
[ler.KM200SwitchProgramServiceHandler] - Negative switch: high
[l.handler.KM200VirtualServiceHandler] - On: /dhwCircuits/dhw1/switchPrograms/A/off  Of: /dhwCircuits/dhw1/switchPrograms/A/high
[l.handler.KM200VirtualServiceHandler] - Full Servicename: /dhwCircuits/dhw1/switchPrograms/cp
[ler.KM200SwitchProgramServiceHandler] - Positive switch: on
[ler.KM200SwitchProgramServiceHandler] - Negative switch: off
[l.handler.KM200VirtualServiceHandler] - On: /dhwCircuits/dhw1/switchPrograms/cp/on  Of: /dhwCircuits/dhw1/switchPrograms/cp/off
[l.handler.KM200VirtualServiceHandler] - Full Servicename: /heatingCircuits/hc1/switchPrograms/A
[ler.KM200SwitchProgramServiceHandler] - Positive switch: comfort2
[ler.KM200SwitchProgramServiceHandler] - Negative switch: eco
[l.handler.KM200VirtualServiceHandler] - On: /heatingCircuits/hc1/switchPrograms/A/comfort2  Of: /heatingCircuits/hc1/switchPrograms/A/eco
[l.handler.KM200VirtualServiceHandler] - Full Servicename: /heatingCircuits/hc1/switchPrograms/B
[l.handler.KM200VirtualServiceHandler] - On: /heatingCircuits/hc1/switchPrograms/B/comfort2  Of: /heatingCircuits/hc1/switchPrograms/B/eco
[l.handler.KM200VirtualServiceHandler] - Full Servicename: /notifications
[ler.KM200SwitchProgramServiceHandler] - !!! Wrong configuration on device. 'on' instead of 'high' in switch program. It seems that's a firmware problem-> ignoring it !!!
Log part 2:
[b.binding.km200.internal.KM200Device] - ##################################################################
[b.binding.km200.internal.KM200Device] - List of avalible services
[b.binding.km200.internal.KM200Device] - readable;writeable;recordable;virtual;type;service;value;allowed;min;max;unit
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatingCircuits
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatingCircuits;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatingCircuits/hc1
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/roomtemperature
[b.binding.km200.internal.KM200Device] - 1;0;1;0;floatValue;/heatingCircuits/hc1/roomtemperature;-3276.8;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/supplyTemperatureSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/supplyTemperatureSetpoint;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/roomTempOffset
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/roomTempOffset;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/activeSwitchProgram
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/activeSwitchProgram;B;A|B;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/designTemp
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/designTemp;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatingCircuits/hc1/temperatureLevels
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/temperatureLevels;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/temperatureLevels/eco
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/temperatureLevels/eco;15.0;;5.0;20.5;C
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/temperatureLevels/comfort2
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/temperatureLevels/comfort2;21.0;;15.5;30.0;C
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/suWiThreshold
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/suWiThreshold;17.0;;10.0;30.0;C
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/operationMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/operationMode;auto;auto|manual;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/fastHeatupFactor
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/fastHeatupFactor;0.0;;1.0;100.0;%
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/currentRoomSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/currentRoomSetpoint;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/heatCurveMax
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/heatCurveMax;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/roomInfluence
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/roomInfluence;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/suWiSwitchMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/suWiSwitchMode;automatic;off|automatic|forced;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/pumpModulation
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/pumpModulation;10.0;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/currentSuWiMode
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatingCircuits/hc1/currentSuWiMode;off;off|forced|cooling;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatingCircuits/hc1/holidayMode
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/holidayMode;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/holidayMode/activated
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatingCircuits/hc1/holidayMode/activated;;|hm1|hm2|hm3|hm4|hm5;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/nextSetpoint
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/nextSetpoint;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/switchProgramMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/heatingCircuits/hc1/switchProgramMode;levels;levels|absolute;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatingCircuits/hc1/switchPrograms
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/switchPrograms;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A
[b.binding.km200.internal.KM200Device] - 1;1;0;0;switchProgram;/heatingCircuits/hc1/switchPrograms/A;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/eco
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/eco;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/nbrCycles
[b.binding.km200.internal.KM200Device] - 1;0;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/nbrCycles;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/weekday
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/weekday;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/cycle
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/cycle;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/A/comfort2
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/A/comfort2;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B
[b.binding.km200.internal.KM200Device] - 1;1;0;0;switchProgram;/heatingCircuits/hc1/switchPrograms/B;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/eco
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/eco;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/nbrCycles
[b.binding.km200.internal.KM200Device] - 1;0;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/nbrCycles;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/weekday
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/weekday;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/cycle
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/cycle;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /heatingCircuits/hc1/switchPrograms/B/comfort2
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/heatingCircuits/hc1/switchPrograms/B/comfort2;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/actualSupplyTemperature
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatingCircuits/hc1/actualSupplyTemperature;36.2;;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/currentOpModeInfo
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/currentOpModeInfo;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatingCircuits/hc1/temporaryRoomSetpoint
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatingCircuits/hc1/temporaryRoomSetpoint;-1.0;;5.0;30.0;C
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/timeToNextSetpoint
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/timeToNextSetpoint;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatingCircuits/hc1/controlType
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatingCircuits/hc1/controlType;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatingCircuits/hc1/cooling
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatingCircuits/hc1/cooling;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatingCircuits/hc1/status
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatingCircuits/hc1/status;ACTIVE;INACTIVE|ACTIVE;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /solarCircuits
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/solarCircuits;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/bus
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/system/bus;EMS2_0;No_Bus|EMS1_0|EMS2_0|CAN;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/appliance
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/appliance;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/appliance/actualSupplyTemperature
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/appliance/actualSupplyTemperature;36.2;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/sensors
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/sensors;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/sensors/temperatures
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/sensors/temperatures;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/sensors/temperatures/outdoor_t1
[b.binding.km200.internal.KM200Device] - 1;0;1;0;floatValue;/system/sensors/temperatures/outdoor_t1;1.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/sensors/temperatures/chimney
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/chimney;-3276.8;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/sensors/temperatures/supply_t1_setpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/supply_t1_setpoint;5.0;;;;
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/supply_t1;36.2;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/sensors/temperatures/return
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/return;35.8;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/sensors/temperatures/hotWater_t2
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/hotWater_t2;56.1;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/sensors/temperatures/switch
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/system/sensors/temperatures/switch;-3276.8;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/healthStatus
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/system/healthStatus;ok;error|maintenance|ok;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /system/minOutdoorTemp
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/system/minOutdoorTemp;-10.0;;-35.0;10.0;C
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/holidayModes
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/holidayModes;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/holidayModes/hm5
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm5;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm5/startStop
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm5/startStop;2017-01-01/2017-01-01;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm5/hcMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm5/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm5/delete
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm5/delete;;
[b.binding.km200.internal.KM200Device] - List type: arrayData service: /system/holidayModes/hm5/assignedTo
[b.binding.km200.internal.KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm5/assignedTo;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm5/dhwMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm5/dhwMode;OFF;AUTO_SAT|OFF|TD_OFF;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/holidayModes/hm2
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm2;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm2/startStop
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm2/startStop;2017-01-01/2017-01-01;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm2/hcMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm2/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm2/delete
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm2/delete;;
[b.binding.km200.internal.KM200Device] - List type: arrayData service: /system/holidayModes/hm2/assignedTo
[b.binding.km200.internal.KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm2/assignedTo;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm2/dhwMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm2/dhwMode;OFF;AUTO_SAT|OFF|TD_OFF;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/holidayModes/hm1
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm1;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm1/startStop
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm1/startStop;2017-01-01/2017-01-01;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm1/hcMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm1/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm1/delete
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm1/delete;;
[b.binding.km200.internal.KM200Device] - List type: arrayData service: /system/holidayModes/hm1/assignedTo
[b.binding.km200.internal.KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm1/assignedTo;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm1/dhwMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm1/dhwMode;OFF;AUTO_SAT|OFF|TD_OFF;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/holidayModes/hm4
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm4;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm4/startStop
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm4/startStop;2017-01-01/2017-01-01;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm4/hcMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm4/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm4/delete
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm4/delete;;
[b.binding.km200.internal.KM200Device] - List type: arrayData service: /system/holidayModes/hm4/assignedTo
[b.binding.km200.internal.KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm4/assignedTo;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm4/dhwMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm4/dhwMode;OFF;AUTO_SAT|OFF|TD_OFF;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /system/holidayModes/hm3
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/system/holidayModes/hm3;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm3/startStop
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm3/startStop;2017-01-01/2017-01-01;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm3/hcMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm3/hcMode;ECO;AUTO_SAT|FIX_TEMP|OFF|ECO;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /system/holidayModes/hm3/delete
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/holidayModes/hm3/delete;;
[b.binding.km200.internal.KM200Device] - List type: arrayData service: /system/holidayModes/hm3/assignedTo
[b.binding.km200.internal.KM200Device] - 1;1;0;0;arrayData;/system/holidayModes/hm3/assignedTo;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/holidayModes/hm3/dhwMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/system/holidayModes/hm3/dhwMode;OFF;AUTO_SAT|OFF|TD_OFF;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/systemType
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/system/systemType;NSC_ICOM_GATEWAY;NSC_ICOM_GATEWAY;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /system/brand
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/system/brand;Buderus;unknown|Bosch|Junkers|Buderus|Nefit|Sieger|Tata|Dakon|Elm|Boulter|Vulcano|Worcester|British Gas|IVT|Geminox|Neckar|Zeus|Milton;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /system/busReq
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/system/busReq;;
[b.binding.km200.internal.KM200Device] - List type: systeminfo service: /system/info
[b.binding.km200.internal.KM200Device] - 1;0;0;0;systeminfo;/system/info;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/chimneyTemperature
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/chimneyTemperature;-3276.8;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/nominalCHPower
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/nominalCHPower;17.0;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/energyMonitoring
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/energyMonitoring;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/minTankLevel
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/minTankLevel;0.0;;0.0;135780000.0;kWh
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatSources/energyMonitoring/startDateTime
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatSources/energyMonitoring/startDateTime;2021-11-16T14:46:44;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/maxTankLevel
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/maxTankLevel;0.0;;0.0;135780000.0;kWh
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/consumption
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/consumption;73.2;;0.0;135780000.0;kWh
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/correctionFactor
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/correctionFactor;1.0;;0.7;1.3;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/energyMonitoring/tankLevel
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/heatSources/energyMonitoring/tankLevel;0.0;;0.0;135780000.0;kWh
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/hs1
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/hs1;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatSources/hs1/flameStatus
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatSources/hs1/flameStatus;off;off|on;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/hs1/actualPower
[b.binding.km200.internal.KM200Device] - 1;0;1;0;floatValue;/heatSources/hs1/actualPower;0.00;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatSources/hs1/type
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatSources/hs1/type;GasBoiler;No_Appliance|OilBoiler|GasBoiler|Heatpump|unknownBoiler;;;
[b.binding.km200.internal.KM200Device] - List type: systeminfo service: /heatSources/hs1/info
[b.binding.km200.internal.KM200Device] - 1;0;0;0;systeminfo;/heatSources/hs1/info;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/hs1/actualModulation
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/hs1/actualModulation;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/actualPower
[b.binding.km200.internal.KM200Device] - 1;0;1;0;floatValue;/heatSources/actualPower;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/supplyTemperatureSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/supplyTemperatureSetpoint;5.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/numberOfStarts
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/numberOfStarts;1977;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/actualDHWPower
[b.binding.km200.internal.KM200Device] - 1;0;1;0;floatValue;/heatSources/actualDHWPower;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/powerSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/powerSetpoint;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/burnerModulationSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/burnerModulationSetpoint;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/electricGrid
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/electricGrid;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/total
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/total;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/total/energyMonitoring
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/total/energyMonitoring;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/burnerPowerSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/burnerPowerSetpoint;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/returnTemperature
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/returnTemperature;35.8;;;;
[b.binding.km200.internal.KM200Device] - List type: systeminfo service: /heatSources/info
[b.binding.km200.internal.KM200Device] - 1;0;0;0;systeminfo;/heatSources/info;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/CHpumpModulation
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/CHpumpModulation;10.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/applianceSupplyTemperature
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/applianceSupplyTemperature;36.2;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/actualCHPower
[b.binding.km200.internal.KM200Device] - 1;0;1;0;floatValue;/heatSources/actualCHPower;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/fuelCell
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/fuelCell;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/ch
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/ch;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/ch/energyMonitoring
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/ch/energyMonitoring;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatSources/ch/energyMonitoring/consumedEnergy
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatSources/ch/energyMonitoring/consumedEnergy;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatSources/ch/energyMonitoring/fuelConsumption
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatSources/ch/energyMonitoring/fuelConsumption;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/pool
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/pool;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/pool/energyMonitoring
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/pool/energyMonitoring;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/workingTime
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/workingTime;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/workingTime/secondBurner
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/workingTime/secondBurner;0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/workingTime/centralHeating
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/workingTime/centralHeating;127544;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/workingTime/totalSystem
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/workingTime/totalSystem;143157;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/actualSupplyTemperature
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/actualSupplyTemperature;36.2;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/fanSpeed_setpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/fanSpeed_setpoint;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/dhw
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/dhw;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/dhw/energyMonitoring
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/dhw/energyMonitoring;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatSources/dhw/energyMonitoring/consumedEnergy
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatSources/dhw/energyMonitoring/consumedEnergy;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /heatSources/dhw/energyMonitoring/fuelConsumption
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/heatSources/dhw/energyMonitoring/fuelConsumption;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /heatSources/sensors
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/heatSources/sensors;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatSources/flameStatus
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatSources/flameStatus;off;off|on;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /heatSources/ChimneySweeper
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/heatSources/ChimneySweeper;off;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/gasAirPressure
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/gasAirPressure;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/systemPressure
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/systemPressure;1.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/actualModulation
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/actualModulation;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /heatSources/nominalDHWPower
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/heatSources/nominalDHWPower;20.0;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /dhwCircuits
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/dhwCircuits;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /dhwCircuits/dhw1
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/charge
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/dhwCircuits/dhw1/charge;stop;stop|start;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /dhwCircuits/dhw1/holidayMode
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1/holidayMode;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/holidayMode/activated
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/dhwCircuits/dhw1/holidayMode/activated;;|hm1|hm2|hm3|hm4|hm5;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /dhwCircuits/dhw1/cpoperationMode
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/dhwCircuits/dhw1/cpoperationMode;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /dhwCircuits/dhw1/switchPrograms
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1/switchPrograms;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A
[b.binding.km200.internal.KM200Device] - 1;1;0;0;switchProgram;/dhwCircuits/dhw1/switchPrograms/A;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/high
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/high;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/nbrCycles
[b.binding.km200.internal.KM200Device] - 1;0;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/nbrCycles;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/weekday
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/weekday;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/cycle
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/cycle;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/A/off
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/A/off;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/cp
[b.binding.km200.internal.KM200Device] - 1;1;0;0;switchProgram;/dhwCircuits/dhw1/switchPrograms/cp;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/cp/nbrCycles
[b.binding.km200.internal.KM200Device] - 1;0;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/cp/nbrCycles;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/cp/weekday
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/cp/weekday;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/cp/cycle
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/cp/cycle;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/cp/off
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/cp/off;;
[b.binding.km200.internal.KM200Device] - List type: switchProgram service: /dhwCircuits/dhw1/switchPrograms/cp/on
[b.binding.km200.internal.KM200Device] - 1;1;0;1;switchProgram;/dhwCircuits/dhw1/switchPrograms/cp/on;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/actualTemp
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/actualTemp;56.1;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/workingTime
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/workingTime;15613;;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /dhwCircuits/dhw1/tdMode
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/dhwCircuits/dhw1/tdMode;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /dhwCircuits/dhw1/temperatureLevels
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/dhwCircuits/dhw1/temperatureLevels;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/temperatureLevels/high
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/dhwCircuits/dhw1/temperatureLevels/high;60.0;;30.0;80.0;C
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/temperatureLevels/off
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/temperatureLevels/off;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/waterFlow
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/waterFlow;0.0;;;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/operationMode
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/dhwCircuits/dhw1/operationMode;ownprogram;Off|high|HCprogram|ownprogram;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /dhwCircuits/dhw1/tdsetPoint
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/dhwCircuits/dhw1/tdsetPoint;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/singleChargeSetpoint
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/dhwCircuits/dhw1/singleChargeSetpoint;60.0;;30.0;80.0;C
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /dhwCircuits/dhw1/cpStartph
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/dhwCircuits/dhw1/cpStartph;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/currentSetpoint
[b.binding.km200.internal.KM200Device] - 1;0;0;0;floatValue;/dhwCircuits/dhw1/currentSetpoint;60.0;;;;
[b.binding.km200.internal.KM200Device] - List type: floatValue service: /dhwCircuits/dhw1/chargeDuration
[b.binding.km200.internal.KM200Device] - 1;1;0;0;floatValue;/dhwCircuits/dhw1/chargeDuration;60.0;;15.0;2880.0;mins
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /dhwCircuits/dhw1/status
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/dhwCircuits/dhw1/status;ACTIVE;INACTIVE|ACTIVE;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /gateway
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/gateway;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/versionFirmware
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/gateway/versionFirmware;04.07.07;;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/instPassword
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/instPassword;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/instAccess
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/gateway/instAccess;off;off|on;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/boschSHPassword
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/boschSHPassword;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/versionHardware
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/gateway/versionHardware;iCom_Low_NSC_v1;;;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /gateway/update
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/gateway/update;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/update/request
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/update/request;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/update/strategy
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/update/strategy;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/update/version
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/update/version;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/update/status
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/gateway/update/status;completed;inprogress|completed|interrupted;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/portalPassword
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/portalPassword;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/uuid
[b.binding.km200.internal.KM200Device] - 1;0;0;0;stringValue;/gateway/uuid;$$PROTECTED$$;$$PROTECTED$$;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/knxPassword
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/knxPassword;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/version
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/version;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/DateTime
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/gateway/DateTime;2021-12-04T23:56:03;;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/userpassword
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/userpassword;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/instWriteAccess
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/gateway/instWriteAccess;off;off|on;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/haiPassword
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/haiPassword;;
[b.binding.km200.internal.KM200Device] - List type: refEnum service: /gateway/logging
[b.binding.km200.internal.KM200Device] - 1;0;0;0;refEnum;/gateway/logging;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/logging/reqBusVar
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/logging/reqBusVar;;
[b.binding.km200.internal.KM200Device] - List type: stringValue service: /gateway/logging/userAcceptance
[b.binding.km200.internal.KM200Device] - 1;1;0;0;stringValue;/gateway/logging/userAcceptance;false;false|true;;;
[b.binding.km200.internal.KM200Device] - List type: $$PROTECTED$$ service: /gateway/logging/switch
[b.binding.km200.internal.KM200Device] - 0;0;0;0;$$PROTECTED$$;/gateway/logging/switch;;
[b.binding.km200.internal.KM200Device] - List type: errorList service: /notifications
[b.binding.km200.internal.KM200Device] - 1;0;0;0;errorList;/notifications;;
[b.binding.km200.internal.KM200Device] - List type: errorList service: /notifications/nbrErrors
[b.binding.km200.internal.KM200Device] - 1;0;0;1;errorList;/notifications/nbrErrors;;
[b.binding.km200.internal.KM200Device] - List type: errorList service: /notifications/errorString
[b.binding.km200.internal.KM200Device] - 1;0;0;1;errorList;/notifications/errorString;;
[b.binding.km200.internal.KM200Device] - 1;1;0;1;errorList;/notifications/error;;
I have started digging into trace logs and source code.
initialize() from KM200ThingHandler.java is never called.
It looks like just the “Bridge Thing” is added and I cannot see anything behind it.
With km200.php I can read out all the information.
Hi and welcome to the forum!
The bridge itself will not hold the channels you are looking for.
You have to create things - those should be available in your inbox.
Within these things you will find various channels.
E.g. the thing “temperatures” holds channels for “hotwater_t1”, “outdoor_t1” and many more.
If they are not in the inbox:
Wait until the bridge is completely online (may take a minute or two).
Goto things, press plus, select the km200 binding, then scan. They should appear now.
Hope this helps
Thomas
