KM200 firmware problem
openHAB 4.1.0 with current KM200 binding, KM200, /gateway/versionHardware “iCom_Low_NSC_v1”
With my Buderus GB 162-15 I found several lines like this during startup (no upgrade procedure taken place).
2024-01-06 15:31:03.233 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:sensor:Heizung:temperatures' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-06 15:30:33.165 [INFO ] [ler.KM200SwitchProgramServiceHandler] - !!! Wrong configuration on device. 'on' instead of 'high' in switch program. It seems that's a firmware problem-> ignoring it !!!
2024-01-06 15:31:03.234 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:sensor:Heizung:temperatures': {thing/channel=Type description km200:sensor:Heizung:temperatures:outdoor_t1 for km200:sensor:Heizung:temperatures:outdoor_t1 not found, although we checked the presence before.}
These messages are quite similar for every KM200 thing.
Does anybody have an idea, if this can be ignored or how to correct this?
More detailled logs what is that all about?
2024-01-28 22:38:01.752 [WARN ] [ort.loader.AbstractScriptFileWatcher] - Script loading error, ignoring file '/etc/openhab/automation/js/test.js'
2024-01-28 22:39:23.484 [INFO ] [ler.KM200SwitchProgramServiceHandler] - !!! Wrong configuration on device. 'on' instead of 'high' in switch program. It seems that's a firmware problem-> ignoring it !!!
2024-01-28 22:39:23.485 [INFO ] [ler.KM200SwitchProgramServiceHandler] - !!! Wrong configuration on device. 'on' instead of 'high' in switch program. It seems that's a firmware problem-> ignoring it !!!
2024-01-28 22:39:23.486 [INFO ] [ler.KM200SwitchProgramServiceHandler] - !!! Wrong configuration on device. 'on' instead of 'high' in switch program. It seems that's a firmware problem-> ignoring it !!!
2024-01-28 22:39:23.487 [INFO ] [ler.KM200SwitchProgramServiceHandler] - !!! Wrong configuration on device. 'on' instead of 'high' in switch program. It seems that's a firmware problem-> ignoring it !!!
2024-01-28 22:39:53.292 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:sensor:Heizung:temperatures' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.294 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:sensor:Heizung:temperatures': {thing/channel=Type description km200:sensor:Heizung:temperatures:outdoor_t1 for km200:sensor:Heizung:temperatures:outdoor_t1 not found, although we checked the presence before.}
2024-01-28 22:39:53.300 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:dhwCircuit:Heizung:dhw1' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.301 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:dhwCircuit:Heizung:dhw1': {thing/channel=Type description km200:dhwCircuit:Heizung:dhw1:charge for km200:dhwCircuit:Heizung:dhw1:charge not found, although we checked the presence before.}
2024-01-28 22:39:53.307 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:appliance:Heizung:appliance' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.308 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:appliance:Heizung:appliance': {thing/channel=Type description km200:appliance:Heizung:appliance:actualSupplyTemperature for km200:appliance:Heizung:appliance:actualSupplyTemperature not found, although we checked the presence before.}
2024-01-28 22:39:53.314 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:heatingCircuit:Heizung:hc1' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.314 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:heatingCircuit:Heizung:hc1': {thing/channel=Type description km200:heatingCircuit:Heizung:hc1:supplyTemperatureSetpoint for km200:heatingCircuit:Heizung:hc1:supplyTemperatureSetpoint not found, although we checked the presence before.}
2024-01-28 22:39:53.321 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:notification:Heizung:notifications' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.322 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:notification:Heizung:notifications': {thing/channel=Type description km200:notification:Heizung:notifications:nbrErrors for km200:notification:Heizung:notifications:nbrErrors not found, although we checked the presence before.}
2024-01-28 22:39:53.328 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:heatingCircuit:Heizung:hc1-switchprogram' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.329 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:heatingCircuit:Heizung:hc1-switchprogram': {thing/channel=Type description km200:heatingCircuit:Heizung:hc1-switchprogram:weekday for km200:heatingCircuit:Heizung:hc1-switchprogram:weekday not found, although we checked the presence before.}
2024-01-28 22:39:53.335 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:system:Heizung:system' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.335 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:system:Heizung:system': {thing/channel=Type description km200:system:Heizung:system:healthStatus for km200:system:Heizung:system:healthStatus not found, although we checked the presence before.}
2024-01-28 22:39:53.347 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:gateway:Heizung:gateway' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.348 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:gateway:Heizung:gateway': {thing/channel=Type description km200:gateway:Heizung:gateway:update_status for km200:gateway:Heizung:gateway:update_status not found, although we checked the presence before.}
2024-01-28 22:39:53.360 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'km200:heatSource:Heizung:heatSources' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2024-01-28 22:39:53.361 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'km200:heatSource:Heizung:heatSources': {thing/channel=Type description km200:heatSource:Heizung:heatSources:nominalCHPower for km200:heatSource:Heizung:heatSources:nominalCHPower not found, although we checked the presence before.}
Were you able to find and rectify the root cause of these messages? For a few weeks now - without any deliberate changes to the configuration - I have been getting the same messages that I didn’t have before. I am with openHAB 4.3.3.
I checked current log files and see no issues
