can someone help me with the following warnings on startup?
Any ideas how to fix them?
2022-08-06 15:59:25.144 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.146 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.150 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.151 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.154 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.156 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.172 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.174 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.178 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.179 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.183 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.184 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.195 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.196 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.200 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.201 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.204 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.206 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.219 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.221 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.224 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.226 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.230 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.231 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.413 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.414 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.428 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.429 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.433 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-06 15:59:25.434 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
I have also started noticing these warnings. It only occurs once on startup for me. I’m on openHAB 3.3.0 Stable release. Any ideas on how to fix these? My warnings below:
2022-08-16 20:57:37.869 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'thing-type:mqtt:string_channel'
2022-08-16 20:57:37.871 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'thing-type:mqtt:string_channel'
2022-08-26 14:53:31.137 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2022-08-26 14:53:35.124 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler KM200GatewayHandler tried updating the thing status although the handler was already disposed.
2022-08-26 14:53:35.128 [INFO ] [internal.handler.KM200GatewayHandler] - Update KM50/100/200 gateway configuration, it takes a minute....
2022-08-26 14:53:40.129 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'km200:kmdevice:307071489' takes more than 5000ms.
2022-08-26 14:55:16.629 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.629 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.630 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.630 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.634 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.634 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.635 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.636 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.636 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.637 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.637 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.639 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.639 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.640 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.640 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.641 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.641 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.642 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.643 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.643 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.644 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.645 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.645 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.646 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.646 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.648 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.648 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.649 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.649 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.652 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.652 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.653 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.653 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.655 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.655 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.656 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.656 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.657 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.657 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.659 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.659 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.660 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.660 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.662 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.663 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.663 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.664 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.664 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.665 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.665 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.666 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.666 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.667 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.667 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.668 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.668 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.669 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.669 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.670 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.670 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.671 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.671 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.672 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.672 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.673 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.673 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.676 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.677 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.677 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.678 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.678 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.679 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.679 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.680 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.680 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.682 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.682 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.684 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.684 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.685 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.685 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.686 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.686 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.687 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.687 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.688 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.688 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.689 [WARN ] [ation.ConfigDescriptionValidatorImpl] - No config description found for URI 'channel-type:km200:config'
2022-08-26 14:55:16.689 [WARN ] [ation.ConfigDescriptionValidatorImpl] - Skipping config description validation because no config description found for URI 'channel-type:km200:config
