Hi everyone,
back in the days (2.5.0) I once migrated to KNX Binding v2, but due to the complexity I stayed on v1. The working knx.things file looked like this:
Bridge knx:ip:KNX “KNX” @ “KNX” [
type=“TUNNEL”,
ipAddress=“192.168.178.34”,
portNumber=3671,
localIp=“192.168.178.33”,
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=30,
localSourceAddr=“1.1.2” ]
Thing device Schaltaktor_20fach_1 “Schaltaktor 20-fach 1” @ “KNX” [ address=“1.1.8”, fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Steckdose_Schlafzimmer_Links “Steckdose Schlafzimmer Links” [ ga=“2/1/1” ]
Type switch : Steckdose_Schlafzimmer_Rechts “Steckdose Schlafzimmer Rechts” [ ga=“2/1/4” ]
Type switch : Elternbad “Elternbad” [ ga=“1/1/37” ]
Type switch : Elternbad_Spiegel “Elternbad Spiegel” [ ga=“1/1/43” ]
Type switch : Kind_Links “Kind Links” [ ga=“1/1/1” ]
Type switch : Kind_Rechts “Kind Rechts” [ ga=“1/1/8” ]
Type switch : GaesteWC “Gäste WC” [ ga=“1/2/8” ]
Type switch : Arbeitszimmer “Arbeitszimmer” [ ga=“1/2/1” ]
Type switch : Werkstatt “Werkstatt” [ ga=“1/3/1” ]
Type switch : Vorratsraum “Vorratsraum” [ ga=“1/3/22” ]
Type switch : Garderobe “Garderobe” [ ga=“1/1/30” ]
Type switch : Kinderbad “Kinderbad” [ ga=“1/1/15” ]
Type switch : Stufenbeleuchtung “Stufenbeleuchtung” [ ga=“1/1/58” ]
Type switch : Flur_OG “Flur OG” [ ga=“1/1/52” ]
Type switch : Schlafzimmer “Schlafzimmer” [ ga=“1/1/22” ]
Type switch : Speisekammer “Speisekammer” [ ga=“1/2/21” ]
Type switch : Flur_EG “Flur EG” [ ga=“1/2/35” ]
Type switch : Fitnessraum “Fitnessraum” [ ga=“1/3/8” ]
Type switch : Dachboden “Dachboden” [ ga=“1/1/50” ]
Now I just got a new RPI and installed OH3 (openhabian) from scratch. I tried to install the bridge, things and channels one by one, but the individual things dont work (thus the underlying channels dont work either).
Here’s the yaml files:
UID: knx:ip:bridge
label: KNX
thingTypeUID: knx:ip
configuration:
useNAT: false
readRetriesLimit: 3
ipAddress: 192.168.178.34
localIp: 192.168.178.33
autoReconnectPeriod: 30
type: TUNNEL
localSourceAddr: 1.1.2
readingPause: 50
portNumber: 3671
responseTimeout: 10
The bridge is ONLINE
UID: knx:device:bridge:Schaltaktor_20fach_1
label: Schaltaktor_20fach_1
thingTypeUID: knx:device
configuration:
pingInterval: 600
address: 1.1.8
readInterval: 0
fetch: true
bridgeUID: knx:ip:bridge
channels:
– id: Steckdose_Schlafzimmer_Links
channelTypeUID: knx:switch
label: Steckdose_Schlafzimmer_Links
description: “”
configuration:
ga: 2/1/1
This thing is OFFLINE, of course the individual CHANNEL is not responding.
The external factors (IP Adress, KNX Configuration, etc) stayed the same, but the individual Things don’t change to ONLINE. If I just paste the whole knx.things file into the things-folder it looks the same: Bridge ONLINE, THINGS OFFLINE. Here’s the log-tail:
2021-02-26 17:36:46.361 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNX’ changed from UNKNOWN to OFFLINE
2021-02-26 17:37:16.369 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNX’ changed from UNKNOWN to ONLINE
2021-02-26 17:37:16.375 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX:Schaltaktor_20fach_1’ changed from OFFLINE (BRIDGE_OFFLINE) to UNKNOWN
2021-02-26 17:37:33.393 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:device:KNX:Schaltaktor_20fach_1’ changed from UNKNOWN to OFFLINE
Any advice / idea?
