Inexplicably when I use my openHab with knx device I receve this message:
- establishing connection failed, timeout connecting to control endpoint
and I lose my KNX/IP Gateway. I Tried all but nothing !!! what can I do ???
Sharing your set up and configuration would be a step towards a solution.
I use the Paper UI with this option:
This is my /etc/default/knxd is
–eibaddr=1.1.128 --client-addrs=1.1.129:8 -D -T -R -S -i --listen-local=/tmp/knx -b tpuarts:/dev/ttyAMA0
please help me !!
As a first test, please remove Local knx PA (Physical Address) or set it to 0.0.0
Did knx2 work as expected any time?
I have a version of knxd that is not good,
knxd 0.14.25 how do I install the current version 0.14.24 ???
I’ve already done this test!!!
Dear Denny
What is your current gateway for Knx connection?
Is it serial or Ip interface?
Serial on AMA0
Which manufacturer?
I am already using weinzierl kberry with knxd, it is working, but no stable.
Default binding (calimero)of openhab 2.3 is better, but it is working with serial ft 1.2 gateways with emi2 protocols.
Ip is stable, working good.
