Hello.
I wounder if sombody no about a good solution to convert knx to bacnet. And mabye modbus to bacnet.
I’m hopeing for a solution where I can exsport a OPC file from ETS and make bacnet object. Running true a converter program on eks. a linux installasjon.
Some of the same function as BACnet IP to KNX - Chipkin Automation Systems, or other solutions like that.
Espen
