I have a KNX binary input that reads a gets triggered by alarm sensors. So when the alarm sensors detect a movement, the binary input receives an ON signal, and an OFF signal when the movement stops. The binary input sends an ON/OFF command to a switch actor so light can be switched.
I want to record this movement in Openhab so I can use it for more complex scripts. Although I see that there is a value recorded in ETS, the openhab logs don’t record this. What am I doing wrong?
Type contact : isMovementOffice [ ga="1.001:<5/2/2" ]
Type contact : isMovementNightHall [ ga="1.001+<5/2/4" ]
I’ve tried different setups, like
[ ga=“1.001:<5/2/2” ]
[ ga=“1.001+<5/2/2” ]
[ “<5/2/2” ]
[ ga=“1.019:<5/2/2” ]
But I never see in the logs that a movement is recorded.
