Hello, i’m configuring OH to connect to working KBX Lan.
This KNX work perfectly with GIRA 2168 IP Interface - Voxio -Alexa and KNX device.
So , i wanto to use openhab to control an device KNX
With Basic UI i’m unable to make work.
Knx Interface are 192.168.1.175 and 1.0.223 Knx add
I want simple to switch on/off a device 1.0.8 that has 2 button 1.5.225 and 1.5.217
Here some screenshoot.
You see that not go on line
Someone can help me to make correct configuration ?
I saw that in knx automatic discover not work like in IP Binding for example…so i need to add all KNX Item manually i suppose.
Configuration chevron_right Things chevron_right Edit chevron_right KNX Device
This is
Configuration chevron_right Things chevron_right KNX Device
— LOG
2020-09-27 11:08:55.403 [hingStatusInfoChangedEvent] - ‘knx:device:f74861ce’ changed from UNKNOWN to OFFLINE
2020-09-27 11:10:31.430 [hingStatusInfoChangedEvent] - ‘knx:device:f74861ce’ changed from OFFLINE to UNKNOWN
2020-09-27 11:10:31.447 [me.event.ThingUpdatedEvent] - Thing ‘knx:device:f74861ce’ has been updated.
2020-09-27 11:10:37.432 [WARN ] [Xnet/IP Tunneling 192.168.1.175:3671] - response timeout waiting for confirmation
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 1.0.223->1.0.8 L_Data.req, system priority hop count 6 repeat, tpdu 80
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:244) ~[?:?]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:258) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:177) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:264) ~[?:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:332) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:243) ~[?:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.connect(TransportLayerImpl.java:327) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.send(ManagementClientImpl.java:796) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.sendWait2(ManagementClientImpl.java:824) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readDeviceDesc(ManagementClientImpl.java:447) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementProceduresImpl.isAddressOccupied(ManagementProceduresImpl.java:310) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.isReachable(AbstractKNXClient.java:341) ~[?:?]
at org.openhab.binding.knx.internal.handler.AbstractKNXThingHandler.pollDeviceStatus(AbstractKNXThingHandler.java:148) ~[?:?]
at org.openhab.binding.knx.internal.handler.AbstractKNXThingHandler.lambda$1(AbstractKNXThingHandler.java:188) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_265]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
2020-09-27 11:10:37.504 [hingStatusInfoChangedEvent] - ‘knx:device:f74861ce’ changed from UNKNOWN to OFFLINE
2020-09-27 11:12:31.706 [.ItemChannelLinkAddedEvent] - Link ‘Lampada-knx:device:f74861ce:SwitchChannel’ has been added.
2020-09-27 11:13:35.277 [ome.event.ItemCommandEvent] - Item ‘Lampada’ received command ON
2020-09-27 11:13:35.349 [vent.ItemStateChangedEvent] - Lampada changed from NULL to ON
2020-09-27 11:13:36.045 [ome.event.ItemCommandEvent] - Item ‘Lampada’ received command OFF
2020-09-27 11:13:36.094 [vent.ItemStateChangedEvent] - Lampada changed from ON to OFF
