Hi Community,
i set up my KNX binding including all channels (also one switch-control channel) in version 2.3.0. Everything worked fine, but since i updated to version 2.4.0 my control switch doesn’t work anymore. I also had the autoupdate problem, but solved the issue with a workaround from another Thread.
All of my KNX Switches are working, also all of my Hue Items are working how they are supposed to. The only Item/Channel that doesn’t work properly is my switch-control. It does switch my hue Lamp on and off, exactly if i would use the original Hue Switch Item, but it does not send or receive commands from the KNX System. Also i can turn the lamp on with my KNX Hardware Switch on my Wall, but not off again.
What should happen (and also worked like supposed to) is, when i turn the HueKnx control switch on/off, the “Musikzimmer” lamp and the Hue lamp both turn on/off.
Here my knx things file:
Bridge knx:ip:44aacde2 [ //Bridge um mit dem KNX System zu kommunizieren, auch in Paper UI konfigurierbar
ipAddress="192.168.178.***",
portNumber=3671,
localIp="192.168.178.***",
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="0.0.0"
] { //KNX Gerät deffinieren (relativ egal ausschließlich um Channel erstellen zu können)
Thing device KNXBus [
address="1.2.3",
fetch=false,
pingInterval=0,
readInterval=0
] { //Channel des Things | KNX Geräte
Type switch:switchLichtFlurErstesOG "Flurlicht 1.OG" [ga="1.001:2/4/0+<2/4/1"]
Type switch:switchSpielzimmerLicht1 "Licht Spielzimmer" [ga="1.001:2/5/0+<2/5/1"]
Type switch:switchSpielzimmerVentilator "Ventilator Spielzimmer" [ga="1.001:2/5/2+<2/5/3"]
Type switch:switchMusikzimmerLicht1 "Licht Musikzimmer" [ga="1.001:2/2/0+<2/2/1"]
Type switch:switchBadezimmmerLicht1 "Deckenlicht Badezimmer" [ga="1.001:2/1/0+<2/1/1"]
Type switch:switchBadezimmerLicht2 "Wandlicht Badezimmer" [ga="1.001:2/1/2+<2/1/3"]
Type switch:switchSchlafzimmerLicht1 "Deckenlicht Schlafzimmer vorne" [ga="1.001:2/0/0+<2/0/1"]
Type switch:switchSchlafzimmerLicht2 "Deckenlicht Schlafzimmer Bett" [ga="1.001:2/0/2+<2/0/3"]
Type switch:switchSchlafzimmerVentilator "Ventilator Schlafzimmer" [ga="1.001:2/0/4+<2/0/5"]
//Weitere Channel | KNX fremde Geräte (Hue)
Type switch-control:controlSwitchHueStehlampe "Hue Stehlampe" [ga="1.001:2/2/0+<2/2/1"]
And here my knx item file:
Group:Switch AllLights "Alle Lichter"
Group:Switch AllVentilatoren "Alle Ventilatoren"
// !Achtung! Autoupdate Funktion der KNX Channels sind ein Workaround für das aktuelle Autoupdate für die aktuelle OpenHAB stable Version 2.4.0
Switch FlurErstesOGLampe "Licht Flur 1.OG" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchLichtFlurErstesOG", autoupdate="true"}
Switch SpielzimmerLampe1 "Licht Spielzimmer" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchSpielzimmerLicht1", autoupdate="true"}
Switch SpielzimmerVentilator "Ventilator Spielzimmer" <ventilator> (AllVentilatoren) {channel="knx:device:44aacde2:KNXBus:switchSpielzimmerVentilator", autoupdate="true"}
Switch MusikzimmerLampe1 "Licht Musikzimmer" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchMusikzimmerLicht1", autoupdate="true"}
Switch BadezimmerLampe1 "Deckenlicht Badezimmer" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchBadezimmmerLicht1", autoupdate="true"}
Switch BadezimmerLampe2 "Wandlicht Badezimmer" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchBadezimmerLicht2", autoupdate="true"}
Switch SchlafzimmerLampe1 "Schlafzimmerlicht vorne" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchSchlafzimmerLicht1", autoupdate="true"}
Switch SchlafzimmerLampe2 "Schlafzimmerlicht Bett" <light> (AllLights) {channel="knx:device:44aacde2:KNXBus:switchSchlafzimmerLicht2", autoupdate="true"}
Switch SchlafzimmerVentilator "Ventilator Schlafzimmer" <ventilator> (AllVentilatoren) {channel="knx:device:44aacde2:KNXBus:switchSchlafzimmerVentilator", autoupdate="true"}
//Hue Stehlampe als KNX Device
Switch HueStehlampeKNX "Hue Stehlampe" <light> {channel="hue:0100:00178862b959:2:brightness", channel="knx:device:44aacde2:KNXBus:controlSwitchHueStehlampe", autoupdate="true"}
Here some log entries:
2019-02-26 10:04:53.229 [ome.event.ItemCommandEvent] - Item 'MusikzimmerLampe1' received command ON
2019-02-26 10:04:53.233 [vent.ItemStateChangedEvent] - MusikzimmerLampe1 changed from OFF to ON
2019-02-26 10:04:53.233 [GroupItemStateChangedEvent] - AllLights changed from OFF to UNDEF through MusikzimmerLampe1
2019-02-26 10:04:57.879 [ome.event.ItemCommandEvent] - Item 'MusikzimmerLampe1' received command OFF
2019-02-26 10:04:57.884 [GroupItemStateChangedEvent] - AllLights changed from UNDEF to OFF through MusikzimmerLampe1
2019-02-26 10:04:57.886 [vent.ItemStateChangedEvent] - MusikzimmerLampe1 changed from ON to OFF
2019-02-26 10:04:58.934 [ome.event.ItemCommandEvent] - Item 'HueStehlampeKNX' received command ON
2019-02-26 10:04:58.937 [vent.ItemStateChangedEvent] - HueStehlampeKNX changed from OFF to ON
2019-02-26 10:05:00.926 [vent.ItemStateChangedEvent] - Light2_Toggle changed from OFF to ON
2019-02-26 10:05:00.927 [vent.ItemStateChangedEvent] - Light2_Dimmer changed from 0 to 31
2019-02-26 10:05:00.982 [ome.event.ItemCommandEvent] - Item 'HueStehlampeKNX' received command OFF
2019-02-26 10:05:00.988 [vent.ItemStateChangedEvent] - HueStehlampeKNX changed from ON to OFF
That happens if i turn the KNX Wall Switch on:
2019-02-25 20:22:39.977 [hingStatusInfoChangedEvent] - 'hue:0100:00178862b959:2' changed from OFFLINE: Die Hue Bridge meldet, dass die Lampe nicht erreichbar ist. to ONLINE
Thanks for all replies and sorry for my englisch ![]()
