I’ve been trying to get Openhab to talk to my KNX system for a couple of evenings now, and for the life of me I can’t get it to work. I’m a newbie to Openhab, so that might explain things.
So far I’m only trying to control 1 light, simple on/off switch. I’m using a Loxone as KNX IP gateway (ip 192.168.1.101, knx address 1.1.1), trying to talk to an actuator (address 1.1.10), to switch on a light (command on 7/0/0 and status on 1/0/0).
I’ve installed the KNX binding through PaperUI, and try to get things working through config files (after reading the documentation and copying some examples there):
knx.things:
Bridge knx:ip:bridge [
type="TUNNEL",
ipAddress="192.168.1.101",
autoReconnectPeriod=60 //optional, do not set <30 sec.
portNumber=3671,
localIp="192.168.1.1",
//readingPause=50,
//responseTimeout=10,
readRetriesLimit=3,
localSourceAddr="0.0.0"
Thing device knx_device { //"knx_device_name" @ "knx_device_group_in_paperui" [
//readInterval=3600 //optional, only used if reading values are present
//address="1.1.10",
//fetch=true,
//pingInterval=300,
//readInterval=3600
//Items configurations
Type switch : demoSwitch "Light" [ ga="7/0/0+<1/0/0" ]
knx.items
Switch demoSwitch "Light [%s]" <light> { channel="knx:device:bridge:knx_device:demoSwitch" }
knx.sitemap
sitemap knx label="KNX Demo Sitemap" {
Frame label="Demo Elements" {
Switch item=demoSwitch
It looks like there’s not even a connection from Openhab to KNX, as I don’t see any movement on the KNX bus when toggling the switch. Furthermore I don’t understand what that switch is doing, as I see the following in events.log (same for ON command):
2019-08-07 23:30:46.439 [ome.event.ItemCommandEvent] - Item 'demoSwitch' received command OFF
2019-08-07 23:30:46.449 [nt.ItemStatePredictedEvent] - demoSwitch predicted to become NULL
What’s that NULL doing there?
Any help would be greatly appreciated!
