I am using ETS5 to manage my KNX home automation and OpenHAB2 to allow me to turn everything on or off using the Android app and my computer.
However, if OpenHAB2 is running while I am performing a device upgrade, it keeps sending T_Disconnect telegrams to my ETS5 and the device in question, making everything slower and eventually even failing the device upgrade.
I’ve included captured traffic logs but they are in ETS5 format and not easily readable (unless you can read KNX wire protocol).
This is a normal update cycle:
<CommunicationLog xmlns=“Die von Ihnen aufgerufene Seite existiert nicht – KNX Association [Official website]”>
<Telegram Timestamp=“2018-11-17T18:08:10.0223791Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B05011100001064E437A5CA70281”/>
<Telegram Timestamp=“2018-11-17T18:08:10.0228001Z” Service=“L_Data.con” FrameFormat=“CommonEmi” RawData=“2E00B0600001111000CE”/>
<Telegram Timestamp=“2018-11-17T18:08:10.0232449Z” Service=“L_Data.con” FrameFormat=“CommonEmi” RawData=“2E00B06000011110037E0A7B97”/>
<Telegram Timestamp=“2018-11-17T18:08:10.0845369Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B0501110000100FE”/>
</CommunicationLog>
While this is one when OpenHAB2 is active:
<Telegram Timestamp=“2018-11-17T18:01:45.3223658Z” Service=“L_Data.con” FrameFormat=“CommonEmi” RawData=“2E00B06000011110036E0C5578”/>
<Telegram Timestamp=“2018-11-17T18:01:45.3452345Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000200010081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.3452982Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000200010081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.6530256Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B0501110000100EE”/>
<Telegram Timestamp=“2018-11-17T18:01:45.6540195Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000211100081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.6541099Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000211100081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.7566596Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B050111000010F424C55780FA1042603C7023AC6031B27”/>
<Telegram Timestamp=“2018-11-17T18:01:45.756963Z” Service=“L_Data.con” FrameFormat=“CommonEmi” RawData=“2E00B0600001111000C2”/>
<Telegram Timestamp=“2018-11-17T18:01:45.7579076Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000211100081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.757972Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000211100081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.7580272Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000200010081”/>
<Telegram Timestamp=“2018-11-17T18:01:45.7580837Z” Service=“L_Data.ind” FrameFormat=“CommonEmi” RawData=“2900B060000200010081”/>
</CommunicationLog>
