Now i am not clear how to transfer the same to chhannel setup in OH4. I can have it running up and down by having 7/1/15 in the address field. but i am lost on the rest.
i know you’re keen on text-configuration from the thread lately. I was, too!
But since I switched to UI-configuration, which is waaaaaaay better. Ok, it’s more copy/paste, but(!) it’s less copy/paste with forgetting to adjust to new things/items configuration.
Give it a try, and it keeps a loooot of work from you.
uuhh. that’s bad, really. You should at least be given the ETS-project by your electrician, which should document the GAs used. Without that, it’s nearly impossible to change the parameters of your actuators.
But you should be able to use 7/1/15 as upDown and 6/1/15 as stop, if it worked with those GA in OH1:
Type rollershutter : demoRollershutter "Shade" [ upDown="7/1/15", stopMove="6/1/15" ]
