Hello!
If I try to save my .items file after adding a dimmer item the log tells me that the listener cannot be informed.
I tried deleting the line of code i inserted but the error does not disappear. a restart did not work as well.
i am running openhabian on a debian virtual machine (OH 3.1 stable).
Here is the log:
2021-12-06 09:46:47.993 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.thing.internal.ChannelLinkNotifier@7efc9988" about the "UPDATED" event: null
at java.util.Objects.requireNonNull(Unknown Source) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.getChannelTypeUID(DeviceThingHandler.java:275) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.isControl(DeviceThingHandler.java:269) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.channelLinked(DeviceThingHandler.java:162) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.lambda$3(ChannelLinkNotifier.java:72) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.call(ChannelLinkNotifier.java:96) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:72) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.updated(ChannelLinkNotifier.java:88) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.updated(ChannelLinkNotifier.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:387) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListenersAboutUpdatedElement(AbstractRegistry.java:408) ~[?:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutUpdatedElement(ItemChannelLinkRegistry.java:150) ~[?:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutUpdatedElement(ItemChannelLinkRegistry.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:314) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:66) ~[?:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:91) ~[?:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:108) ~[?:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:76) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:372) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:212) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:407) ~[?:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) ~[?:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) ~[?:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) ~[?:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:312) ~[?:?]
at org.openhab.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:322) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
Things snippet:
Thing device Schalter "KNX Schalter" [
readInterval=3600
Type dimmer : KG_Garage_Tor_Position_Status [ position="+<1/6/1" ]
Items snippet:
Dimmer KG_Garage_Tor_Position_Status "Garagentor Status" {channel="knx:device:bridge:Schalter:KG_Garage_Tor_Position_Status"}
I hope you can help.
Thanks a lot!
