Hello Guys.
I’m using KNX Binding version 1.9 (installed from PaperUI on OH2)
It worked correctly, when using it in Tunnel mode, but now i wanna set it to be in Router Mode, this makes a million lines in my log file - but the communication works, i get this:
[Link notifier] process link 224.0.23.12:3671: unsupported APDU service - ignored, service code = 0x240
and also
Ignoring local Event, received from my local Source address 15.15.2 for Group address 0/2/100.
I’ve set the ignorelocalevent=True in the config file, also when running Tunnel Mode.
Have you enabled “Reliable Communications” in your ETS for your KNX/IP Router? Try disabling this option to see if the “unsupported APDU service” exception goes away.
Hello again.
Here’s the log from the OH2 where the KNX binding are in debug mode… I can’t find the “Reliable Communication” in the ABB Router configuration. I attached my router configuration…
How to disable the log for the KNx binding again? It spams my log file
Enter in Karaf console: “ssh openhab@localhost -p 8101” (password: habopen)
Check log levels: “log:list”
Set KNX to Error: “log:set ERROR org.openhab.binding.knx”
Set Calimero to Error: “log:set ERROR tuwien.auto.calimero”
Your log looks good. You can safely ignore the warnings.
