I searched for a long time here in the community and in the wiki on github but didn’t find sufficient examples and/or howtos for a (in my opinion) pretty standard use case: automating a room temperature controller (RTR) with openHAB.
In my case it’s GIRA TS3+ (GIRA 514200, 514500), which is configured to control the heating of the rooms. What I want to achieve:
- read out the outputs (setpoint and actual temperature, operating mode, …)
- write the inputs (operating mode, setpoint temperature)
For this, I configured in the ETS the respective group adresses (the RTR uses 1Byte operating mode switch and 0.1K setpoint shift):
- 8/5/11: Output: Controller status
- 8/1/3: Output: Setpoint temperature
- 8/1/1: Output: Actual temperature
- 8/1/2: Input: Basic setpoint
- 8/5/1: Input: Operating mode switchover
Unfortunately, I didn’t find a actual Item-type in openHAB, which could represent the 4-types of the Operating mode like [1="Comfort", 2="Standby", 3="Night", 4="Frost"]. And I didn’t came up with a solution to do this with just one Item. So the workaround is to place the item as switch and setpoint for temperature (I assume, KNX-binding is up and running):
heating.items:
/* Raum-Thermostate und -Regler */
Number RTR_EG_WoZi_actualTemp "Ist Wohnzimmer [%.1f °C]" <temperature> (EG_WoZi, dTemp) { knx="9.001:8/1/1" }
Number RTR_EG_WoZi_setTemp "Soll Wohnzimmer [%.1f °C]" <temperature> (EG_WoZi) { knx="9.001:8/1/2+9.001:8/1/3" }
Number RTR_EG_WoZi_HVAC_mode "Betriebsart" <temperature> (EG_WoZi) { knx="5.005:8/5/1+5.005:8/5/11" }
sitemap:
Switch item=RTR_EG_WoZi_HVAC_mode mappings=[1="Komfort", 2="Standby", 3="Nacht", 4="Frost"]
Setpoint item=RTR_EG_WoZi_setTemp minValue=5 maxValue=28 step=0.1
Only thing I miss, are changes in the UI, if the setpoint item is used (the temperature is updated, but the change is only visible after a page reload) and if the items are changed via KNX. In both cases a page reload helps, but is not triggered onChange.
Is this still the bug in this issue: UI element type "Setpoint" does not update the value · Issue #66 · openhab/openhab-ios · GitHub ?
