Unsure whether I am doing something wrong or whether I have uncovered a bug.
If I define an item bound to a KNX -control channel with a Temperature dimension then OpenHAB doesn’t respond when I query the GA.
Number:Temperature i_LookAheadTemperature "Lookahead 1-4hr temp [%.2f %unit%]" <temperature> (gTemps) { channel="knx:device:multicast:modes:outside_temperature_forecast" }
If I remove the dimension then it responds as expected.
The corresponding bridge/thing definition is:
Bridge knx:ip:multicast "IPR Multicast" @ "KNX" [
type="ROUTER",
ipAddress="224.0.23.12",
localIp="192.168.32.251",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=30 ]
Thing device modes "KNX Modes" @ "KNX" [ fetch=false, pingInterval=600, readInterval=0 ]
// Heating Control Modes
Type switch : PIR_Lighting_Night_Mode "PIR Lighting Night Mode" [ ga="0/0/11" ]
Type switch : Heating_Frost_Protection "Heating Frost Protection" [ ga="0/6/8" ]
Type switch : RTC_Night_Mode "RTC Night Mode" [ ga="0/6/9" ]
Type switch : RTC_Comfort_Mode "RTC Comfort Mode" [ ga="0/6/23" ]
Type number-control : outside_temperature_forecast "Outside Temperature Forecast" [ ga="9.001:0/6/201" ]
Running on Intel/Docker/OpenHAB 2.5.9 with an ABB IPR/S 3.1.1 as the bus interface.
Regards
Mark
