we need knx data secure support in knx calimero library as in the latest version only knx secure IP support is there.
So I am requesting here to please add support of knx data secure in calimero library.
See here:
So it’s on the way
I have a KNX IP secure setup which works fine while using ETS (using its backbone key) but when I tried with KNX Calimero Secure it is not working I am able to make the connection with KNX IP secure but not able to operate any relay/dimmer and also when I am operating from ETS on the event listeners of the calimero no responses were there.
Here is the link to the code I am using
