KNX datatype 251.600 for RGBW
Dear all,
Does the KNX binding for OH2.4 (2.5) support the 251.600 datatype enable RGBW controlling?
If not, any workaround possible ?
Regards,
Luc
Hi Luc,
I’m also interessted in the data type. Have you already found a solution?
KR,
JPF
Dear JPF,
currently, I am applying a workaround using the HSBtype color wheel and convert it to RGBW values by using rules.
I used following thread as template : https://community.openhab.org/t/light-color-rgb-rgbw-rgbcw-to-and-from-hsb-dimmer-conversion/39132
Hope this helps
Regards,
Luc
