KNX Datetime openhab 3 Deutscher Neuling
Continuing the discussion from KNX Datetime from openhab:
Hallo,
ich hoffe hier kann jemand Deutsch :slight_smile:
Bei mir läuft openhab 3 ich verstehe nicht so ganz wie ich das ganze in meine knx.things einbinden kann
meine sieht zur Zeit so aus.
Bridge knx:ip:bridge “Raspi3Tunnel” [
ipAddress=“192.168.2.150”,
localIp=“192.168.2.192”,
type=“TUNNEL”,
portNumber=3671,
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=60,
localSourceAddress=“0.0.0” // this physical address must be unused (even used by tunnel is not allowed!)
Thing device 1 “AKS-1216.03 Schaltaktor 12-fach, 8TE, 16A” [
address=“1.1.5”,
fetch=false,
pingInterval=600,
readInterval=0
Type switch : Kanal_A “Flur” [ga=“1/0/6”]
Type switch : Kanal_B “Wohnen_OG” [ga=“2/0/0”]
Type switch : Kanal_C “Computer_OG” [ga=“2/0/2”]
//Type switch : Kanal_D “” [ga=“”]
Type switch : Kanal_E “Ufo” [ga=“1/0/16”]
//Type switch : Kanal_F “” [ga=“”]
//Type switch : Kanal_G “” [ga=“”]
//Type switch : Kanal_H “” [ga=“”]
//Type switch : Kanal_I “” [ga=“”]
Type switch : Kanal_J “Gäste_WC” [ga=“1/0/10”]
//Type switch : Kanal_K “” [ga=“”]
//Type switch : Kanal_L “” [ga=“”]
  //Type switch : ch3 "Channel 3" [ga="1/1/5+<1/1/6"]
Thing device 2 “AKU-1616.02 Universalaktor 16-fach, 16A, 230VAC” [
address=“1.1.6”,
fetch=false,
pingInterval=600,
readInterval=0
//Type switch : Kanal_A “Channel 2” [ga=“1/2/1+<1/2/2”]
//Type switch : Kanal_B “Channel 2” [ga=“1/2/3+<1/2/4”]
//Type switch : Kanal_C “Channel 3” [ga=“1/2/5+<1/2/6”]
//Type switch : Kanal_D “Channel 1” [ga=“1/2/1+<1/2/2”]
//Type switch : Kanal_E “Channel 2” [ga=“1/2/3+<1/2/4”]
Type switch : Kanal_F “Beleuchtung_Eingang” [ga=“1/4/1”]
Type switch : Kanal_G “Beleuchtung_Terrasse” [ga=“1/4/7”]
//Type switch : Kanal_H “Channel 2” [ga=“1/2/3+<1/2/4”]
//Type switch : Kanal_I “Channel 3” [ga=“1/2/5+<1/2/6”]
//Type switch : Kanal_J “Channel 1” [ga=“1/2/1+<1/2/2”]
Type switch : Kanal_K “Schlafzimmer” [ga=“1/2/0”]
//Type switch : Kanal_L “” [ga=“1/2/5+<1/2/6”]
Type switch : Kanal_M “Miles” [ga=“1/2/2”]
//Type switch : Kanal_N “Channel 2” [ga=“1/2/3+<1/2/4”]
Type switch : Kanal_O “Bad” [ga=“1/2/4”]
//Type switch : Kanal_P “Channel 1” [ga=“1/2/1+<1/2/2”]
Thing device 3 “AKD-0401.01 Dimmaktor1 4-fach, 8TE, 230VAC, 250W” [
address=“1.1.7”,
fetch=false,
pingInterval=600,
readInterval=0
Type dimmer : Kanal_A “Schlafzimmer” [ switch=“1/1/0+<1/1/2”, position=“1/1/30+<1/1/3”, increaseDecrease=“1/1/1” ]
Type dimmer : Kanal_B “Miles” [ switch=“1/1/4+<1/1/6”, position=“1/1/32+<1/1/7”, increaseDecrease=“1/1/5” ]
Type dimmer : Kanal_C “Bad” [ switch=“1/1/8+<1/1/10”, position=“1/1/34+<1/1/11”, increaseDecrease=“1/1/9” ]
Type dimmer : Kanal_D “Kueche” [ switch=“1/1/12+<1/1/14”, position=“1/1/36+<1/1/15”, increaseDecrease=“1/1/13” ]
Thing device 4 “AKD-0401.01 Dimmaktor2 4-fach, 8TE, 230VAC, 250W” [
address=“1.1.8”,
fetch=false,
pingInterval=600,
readInterval=0
Type dimmer : Kanal_A “Wohnzimmer” [ switch=“1/1/16+<1/1/18”, position=“1/1/28+<1/1/19”, increaseDecrease=“1/1/17” ]
Type dimmer : Kanal_B “Esstisch” [ switch=“1/1/20+<1/1/22”, position=“1/1/29+<1/1/23”, increaseDecrease=“1/1/21” ]
Type dimmer : Kanal_C “Totesstern” [ switch=“1/1/24+<1/1/26”, position=“1/1/33+<1/1/27”, increaseDecrease=“1/1/25” ]
Type dimmer : Kanal_D “Bad2” [ switch=“1/1/37+<1/1/39”, position=“1/1/35+<1/1/40”, increaseDecrease=“1/1/38” ]
Thing device Date_Device {
     Type datetime-control : knxTime  [ ga="10.001:1/3/0" ]
 Type datetime-control : knxDate [ ga="11.001:1/3/1" ]
 Type datetime-control : datumzeit  "Datum und Zeit" [ ga="19.001:1/3/2" ]
wenn ich den code einfüge funktioniert meine ganze knx.things nicht mehr hab es noch nicht so ganz verstanden wie das mit der knx.things funktioniert es gibt aber nur eine knx.things bzw es darf nur eine geben. Wäre echt sehr nett wenn es mir jemand erklären könnte.
Schönes Wochenende euch allen.
This is an international forum, the only language is English so more people from all over the world can benefit from it.
If you want to write in German language, please use these forums instead:
Good luck.
