Hello everybody
I’m a newcomer with Openhab, did first installation few months ago, now I’m running version 2.4. So far I’ve done just basic KNX configuration, mainly lighting and heating.
Now i got stuck with KNX dimmer, i can normally switch dimmable lights on and off, but dimming is not working. I can see on Zennio’s touch panel that command is send to KNX bus because dimmer percentage changes when I try dimm light with OH.
I’ve read documentation, community posts, but no solution yet. Could you please help me?
Channel configuration is as follows
and .item
Dimmer Light_Diningroom_Spot_307 "Ruokailutila testi [%d %%]" <slider> (Dim, LivingDining) {channel="knx:device:932f15e3:307"}
Thank you already for your help
rgds Jukka
